Moving data from 2 HDDs to 1 HDD -
Fair warning, I don’t mess around with Linux much anymore. As in, my last daily distro was Mandrake 5.x (I think).
I am getting ready to move 2 HDD’s (3 and 2 TB, into a 12 TB drive. I want to consolidate them to as one currently has Movies and the other has TV Shows. That being said, the path of them is problematic. They are located at:
HTPC\Plex\Movies\Public\Movies
HTPC\Plex\TV Shows\Public\TV Shows
Ideally, I would like to shorten up their location, which I should be able to according to this article: https://support.plex.tv/articles/201154537-move-media-content-to-a-new-location/
I moved all of my content over an external enclosure, but was that a mistake? I currently have the drive formatted as ext4. I now I still need to do partitions, and IIRC, I cannot do that through GNOME. So, command line it is. I will pull my headless server out of the utility room and get to work on it at my desktop. What am I missing to move an external HDD internal? Is it just the permissions? I know this has got to be really basic, but I am missing something. I also seem to remember their being a really nice write up on doing this in Linux, but I just can’t find it right now. If anyone has a link, that would be awesome.
Server Version#: 1.25.3.5409
Ubuntu 20.04.3 LTS - GNU/Linux 5.4.0-96-generic x86_64
This basic ? :slight_smile:
That is the exact article I was thinking of. Thanks so much!
And now that I think about it, I wonder if I might not be better off migrating to my Nvidia Shield Pro. I would have to reformat, but I have the server config backed up. What would I lose going from an i5-9400? I plan on only 1 HDD (with backups on my main desktop).
You would lose the CPU power – burning subtitles & converting audio.
The Shield CPU is good but not “I5 class”
Fair enough. And now that I think about it, I would lose my DVR and OTA TV. Alrighty then, off to do some reading. Thanks so much.
So this is weird, I went to do everything and my keyboard won’t work on my Ubuntu 20.04 box. Any ideas? I can’t even find the accessibility option to use a virtual keyboard. I couldn’t even get it to work doing boot up to go into the BIOS/UEFI.
get a new keyboard. what you have must be ancient or defective
Weird. It worked on the box 4-5 months ago when I pulled it out to do some backups. And its working on this system.
bad usb connector slot?
Tried that. I switched it with the working slot for the Mouse (which works). This is really weird. I went in through putty and checked to make sure nothing needed to be updated. I went through these steps:
Which didn’t work. Then, I tried out the on-screen keyboard, and THAT doesn’t work. So, I may have to blow it all up. Unless anyone can think of anything, I’ll disconnect my current HDD’s in there, reformat the SSD, and then reconnect them, re-add them, then start the backup process.
I got the on screen keyboard to work. Moving over everything now. This is going to take a while.
Just to follow up, I figured out what went wrong with the keyboard. I had my external BD drive plugged into my Keyboard (USB2.0) port. So, I was just moving my mouse and BD drive back and forth. Shocking that I couldn’t get into the BIOS by hitting the Del key. Anyway, got that done, and foolishly updated the BIOS and lost my Intel Ethernet driver somehow. Tried a few things, tried switching from NetworkManager to networkd, back again. To sum up, after 3 short hours on a snow day, I got network connectivity back. So, back to working on the HDD switch.
When you finally get it all working again???
DON’T TOUCH IT!
:rofl:
Not going to lie, once I got it going again, I had a couple beers. I actually really tempted to just go for a networked enclosure, let my Nvidia Shield act as the server, and then just sell the i5-9400 box. I need a new TV tuner anyway, and I might just go with an HDhomerun and get the ATSC with the hopes that Plex will get the licensing figured out for DVR. Man, Linux is just a world of its own.
Linux is definitely not for the timid.
It will do EXACTLY what you tell it… Including :hocho: your fingers off.
I’ve been doing this for several decades now and it still surprises me at times.
Once you do understand it – it’s fantastic :slight_smile:
