Moving Database to another location
Hi
Plex keeps adding new content with a future date - so I’m thinking I might need to move my database to a less utilised drive.
All instructions online reference a setting in the PMS UI called "‘The path where local application data is stored’ - however this seems to have been removed from the Plex UI.
So how do I move the Database to a different folder now?
Running Ubuntu 18.04
David
David,
If PMS is adding your media with a future date, Please check:
  1. Your TimeZone and region settings.
  2. The system clock.
Moving your PMS library is very easy.
It’s adding some new content 78 years in the future. It’s not my system clock or timezone settings
I didn’t mention initially that I’m running a docker image - so I just moved the config folder and changed the volume reference.
I will release this to the Docker side as I’m not sure how to deal with Docker. (don’t understand the nuances)
