Moving metadata from one NAS to another
Well after moving the Library folder and then doing the library mapping cleanup (including trash empty) and it seems everything has transitions over completely.
HI.
Is “DOWNLOAD DATABASE” button same metadata ? I pressed it and got 10MT ZIP file. HOw do I install backup back to PleX?
Im movin to new NAS and want to copy all metadata and settings to new nas.
What is NAS2NAS? I tried googling it but could not find such app for Qnap?
Nope, it’s as the name said the database only
Metadata is also arts and posters
HI. I tested that but there is no local folder that has Plex data. Only shered folders can be copied. So next I need to fiqure how to copy plex settings and metadata…
Read the whole thread!
You need to install my PMSLibShare
Thanks. I did. And got it to work. Next step is Learning how to start Ubuntu Docker with Nvidia drivers. Then If I understood quide correctly I Have to make anothet Ubuntu Docker and RUn PLEX in it? I have never used Linux/Ubuntu, or ever they all are… =)
Ok… I Got Docker to work… but When I log in to Plex, I cannot find Any servers. I used Official PMS container. How and Where Do I then configure server, my metadata and folders to be found…?
SErver found, but no GPU use… only CPU…
Continue here: Hardware Accelerated Decode (Nvidia) for Linux
Please start a new thread for new questions…
First of all people that helped you with the first questions, might not know answers to second one, and if having multiple Q’s in same thread, it’s hard for others to search for answers, as well as join, if determining only from subjet of the thread!
Closing this
