Can anyone tell me how to not loose the watched status and library metadata as I have to move the library to another drive.
Bjarni Sig
Bjarni Sig
the watched status and metadata is not kept in the library, it's kept here
https://support.plex.tv/hc/en-us/articles/201539237-Backing-Up-Plex-Media-Server-Data
Hi and many thanks for your answer Monsieur Latte,.
As there are over 2 GB in the plex media server directory I would very much like to know in what file or files exactly the watched status is and can that file be copied over the same file to restore that watched status?
Bjarni Sig
That link covers everything.
Read the link. Yet another reason Plex is a complete fail for the average computer literate person. Not saying you're wrong as I've become accustomed to this kind of stuff with Plex, but there has to be a simpler way.
Another result of geeks designing software instead of users.
Thanks for the positive feedback to this users issues!
Bjarni, that really sounds like a permissions issue if plex isnt seeing all the new media. Is it on a different share on the Drobo or is it in the same share but a different folder? Can you provide screen shots?
Unfortunately it seems like no one can help me fix my problems so I'll try to blow away Plex and do a complete re-install. It that doesn't work then goodbye Plex and hello any other media manager I can find.
Anyone have any suggestions as an alternative to Plex?
Thanks,
Steve
Thanks,
Steve
I am sorry you feel Plex is not working for you and that you did not get the support you were looking for. If you are still trying to figure this out, check your PMS settings => server => library => Empty trash automatically after every scan. If that is enabled, it removes the old entry when it scans the new one, which would explain why you do not get the 2. You needed to disable this first before step 1 even.
Thanks MovieFan. I'll give it a go and get back to you.
@Tartufo said:
Monsieur Latte wrote on March 2 2015, 7:27 PM: »the watched status and metadata is not kept in the library, it’s kept here
https://support.plex.tv/hc/en-us/articles/201539237-Backing-Up-Plex-Media-Server-DataRead the link. Yet another reason Plex is a complete fail for the average computer literate person. Not saying you’re wrong as I’ve become accustomed to this kind of stuff with Plex, but there has to be a simpler way.
I take umbrage to that. I am a software geek that designs good software. IMHO the plex database was designed by a crazy person, a community, or perhaps a crazy community.
Care to elaborate on the problem with Plex’s database design?
Honestly the internet has been around long enough now. People know what Google is and they know how to use it to look up funny dog memes. No reason people can’t use it to solve Plex issues. The average person is used to the want it get it lifestyle. Its everywhere. Plex is great, it’s amazing! It simply works, and I have used it on almost every platform available today. I just got finished building a new rackmount with a seperate zpool storage for my media. This thing is amazing. I will say this, I have one of the largest libraries I have ever seen on the internet today, and I’ve actually paid to be on some people’s servers. Their library didn’t come close to mine.
There is nothing this software won’t do if you know how to do it. That plus the Sonarr stuff, Couchpotato, and now Docker to make all our lives easier…Plex is here to stay. Getting a powered antenna tomorrow so I can take advantage of the DVR functions of Plex too. Thanks for listening everyone. This post is merely to encourage people when they seem discouraged. My Plex journey has been a long one, and I often Teamviewer into people’s setups to help them further along their media center dreams. I am here to help if anyone needs it.
It doesn’t seem like it’s possible to move ONE library to another server though, gonna be a pain to retag all those files.
Is this other server new or an existing one. If i’ts going to be brand new, you can copy your current setup then delete the other libraries you don’t want anymore. If it’s an existing server and you just want to move things from 1 server to another, there isn’t a way within Plex to do this, but it may be possible with some manual database editing.
If you’re referring to me, yes the new server is new so to speak, the thing is that i don’t want it to be named the same or keep unique id’s and whatnot, i just want the library metadata and the watched data to transfer.
@mrbrax - Sorry, yes. I was responding to your post.
You can follow the steps in https://support.plex.tv/hc/en-us/articles/201370363-Move-an-Install-to-Another-System to create a copy of your server’s data. Skip the part about the Windows registry, Mac com.plexapp.plexmediaserver.plist file, or Linux preferences.xml file, which ever OS you are running. That’s the part that identifies the server. This will copy all your libraries, custom metadata and posters, and watched status.
@mrbrax - Sorry, yes. I was responding to your post.You can follow the steps in https://support.plex.tv/hc/en-us/articles/201370363-Move-an-Install-to-Another-System to create a copy of your server’s data. Skip the part about the Windows registry, Mac com.plexapp.plexmediaserver.plist file, or Linux preferences.xml file, which ever OS you are running. That’s the part that identifies the server. This will copy all your libraries, custom metadata and posters, and watched status.
I think it’s my 3rd or 4th Plex migration on Windows 7/10 so my setup get’s optimal and was procrastinating doing it not to loose all metadata/watched/tags of all my users since I’ve never been able to migrate to another system without ending up installing from scratch.
In my case reimporting the REGISTRY into my destination server had the impact of corrupting Plex Media Server somehow. PMS ended up running but the web portal was unresponsive so, not a good sign.
I’ve followed your recommendation MovieFan.Plex, ignoring the import of REGISTRY and attempted to run the initial setup wizard… flawless. First step, name the server, the second step suggested… we’ve found existing libraries… VICTORY!!
The path to the medias were all broken since the new server assigned a new letter to my media files, I’ve changed it back using Windows Computer Management tool, rebooted… everything got fixed at that point.
My recommendation to anyone owning a somehow serious Plex Media Server is to install Plex and all medias on it’s own machine. Any other software to complement your installation rather be in installed on a different machine (CouchPotato, Sickbeard, SABNZDB, PlexPy), so no external process impacts it’s primary purpose.
Investigating issues on a simpler installation is easy so no users are impacted by inconsistant streaming, transcoding, bandwidth availabilities, CPU and RAM availability.
@jmcgeejr said:
the watched status and metadata is not kept in the library, it’s kept herehttps://support.plex.tv/hc/en-us/articles/201539237-Backing-Up-Plex-Media-Server-Data
Does this backup all data or just the library? I’m wanting to do a fresh install of Plex with the default settings, but I don’t want to have to retag all of my videos.
Yes, that will back up all of PMS. Make sure when restoring that you use the same version of PMS to avoid issues. Or update PMS before you do the backup.
