I try to give me permission both trough the folder permission, and also trough group permission, but the folder doesn’t appear. I try to delete the Plex folder?
We have updated the builds linked in the original post to a new 1.14.0.391-7623e9224 version. The most notable additions/fixes that apply to the preview are listed below;
… And it’s a fails…
This package don’t work in QNAP TS-832X ARM V8.
I’ have a QNAP TS-832X runing with QTS firware 4.3.4.0695
Still the same error… @chrisallen, @ChuckPa please do something
(Can you just tell me where i can find this library with the good compilation ?)
[/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer] # ./plex.sh start
Starting Plex Media Server...
[/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer] # ./Plex Media Server: error while loading shared libraries: libcurl.so: ELF load command alignment not page-aligned
If it can help :
[/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer] # cat /proc/cpuinfo
processor : 0
model name : Annapurna Labs Alpine AL324 Quad-core ARM Cortex-A57 CPU @ 1.70GHz
Features : fp asimd evtstrm aes pmull sha1 sha2 crc32
CPU implementer : 0x41
CPU architecture: 8
CPU variant : 0x1
CPU part : 0xd07
CPU revision : 3
processor : 1
CPU architecture: 8
CPU variant : 0x1
CPU part : 0xd07
CPU revision : 3
processor : 2
CPU architecture: 8
CPU variant : 0x1
CPU part : 0xd07
CPU revision : 3
processor : 3
CPU architecture: 8
CPU variant : 0x1
CPU part : 0xd07
CPU revision : 3
@tamas : No ! (Check my earlyear post in date of 02/10 )
The last working version is : PlexMediaServer-1.13.6.176-dd1845234-aarch64.qpkg
Downloaded here : QNAP [aarch64 / ARMv8]
I’m at your service for testing
If it can help @ChuckPa reproduce this issue in his device with last time.
It’s very likely that you will run into the same issue with other libraries even if you manage to compile a curl that works, so I don’t suggest sinking time into this. That said, if you still want to try it, our curl version is: 7.56.1.
We are cross-compiling for QNAP, but it’s a really involved setup. We’ve been working on it for two years. You won’t have to wait that long for a new build this time, hopefully
