Multiple movie versions
Hello,
I would like to ask if PLEX have some feature how to present same movie with multiple versions. I dont mean multiple video quality like SD, HD, 4k I mean like directors cut, chroma/black and white edition, alternate endings etc.
I only saw that PLEX makes 2 separate quality for same movies but is there a way how to distinctly show that some movie have 2 or more versions? Something like open movie detail and there will be some big posters along with the main one that lead you to another movie versions?
There’s a rather popular feature suggestion to support different editions/cuts of movies (in difference to different quality versions). From what has been posted in that thread it seems to be worth to stay tuned :wink:
Edit: if you have 2 different versions merged, you should already have an option to split them apart from the library item’s context menu. Though it might be worth to wait a little.
