Multiple repeat instances of shows in Program Guide on the Shield and iPhone
Got Live TV up and running with the HDHomeRun Prime today. One issue I am having is that there are as many as 6 entries (labels…or whatever they’re called) for the same show, on the same channel. It makes the program guide annoyingly longer to scroll through with so many entries for each show. Only does this on the Shield and my wife’s Phone. Plex Web shows only one entry for each show through the web browser.
Any ideas…?
I’m seeing the same thing on my iPhone. I’m also seeing on the Web client, a bunch of items that don’t ever load and just say "loading…:. Just to rule things out: you didn’t recently move your local app data in settings did you?
I did and just want to rule that out as a cause.
Mine was doing the same thing last night. Thanks to Microsoft’s 2nd Tuesday updates I had to reboot my server. Once it was back up, Plex started refreshing the program guide and it appears to be just fine now. No duplicates…
