Multiple versions shows up as duplicates?
Hi All
Using the naming standard for multiple version like:
Wonder Woman (2017) - 720p
Wonder Woman (2017) - 1080p
Wonder Woman (2017) - 4K
Plex keeps seeing them as duplicates?
Before if I was naming them correctly it would shows as one single movie?
What am I doing wrong?
If they are in the same folder, it should see them as a single video. e.g.
/movies/Movie Title (year)/Movie Title (year) - quality A.ext
/movies/Movie Title (year)/Movie Title (year) - quality B.ext
Whereas if they are completely separated by quality it will see it as a duplicate. e.g.
/movies/Movie Title (year) - quality B/Movie Title (year) - quality A.ext
/movies/Movie Title (year) - quality B/Movie Title (year) - quality B.ext
For optional information in the filename you should surround them in brackets.
Wonder Woman (2017) [720p]
Wonder Woman (2017) [1080p]
Wonder Woman (2017) [4K]
I have the movies in the same folder! still shows up under duplicates?
Also the Plex standard does not state anything about brackets se here:
LINK
Hmm… I used to have it set up the way you have above when i had 1080/4k before splitting the libraries… and now that i think about it it did show a [2] on the poster, but when i went to the movie and selected ā€œVersionā€ it allowed me to choose. If you are looking to not have a [2] there i dont think it will do that… because there ARE 2 files. Do you get a different result if you ā€œOptimizeā€ a movie where plex does the separation of versions?
I think Plex creates a subfolder with a mv4 file when using ā€œOptimizeā€ I haven’t tried this.
Because I prefer to have all my files in mkv containers.
Come to think about it the icon with 2 files indicates that the movie is in 2 different version and I can select the one I want thats okay!
But if I go to the movie library and select Duplicates it will show all the movies I have wich contains different versions!
I think this is an ERROR in Plex, because it should ignore them if the naming is correct, and only list duplicates between folders…
I prefer MKV as well.
Duplicates is an ambiguous term unfortunately. I guess the logic could be rewritten to say if files are not in the same folder but that would break all libraries where people do not subfolder their media. This might be a situation where its ā€œwhat appeases the massesā€. Doesnt hurt to post something in the requests section tho! If my above answer answered your question, please mark it as such. Thanks!
The scanner will normally ignore stuff after the year. Using the brackets is just an explicit way to make sure the scanner ignores stuff.
Can you explain exactly what you mean by duplicate? Do you mean duplicate as in multiple copies of the movie being shown next to each other? If so, please provide me the xml from 2 of these duplicates.
Duplicate as in when you click duplicates as a sort option it will show you all movies that there is >=2 versions of
Those are the same thing, hence my confusion. If the op does not see them grouped into 1 entry, then they shouldn’t show up under the ā€œduplicateā€ filter.
I see your confusion. I am assuming that as he continued the conversation after I specified the [2]. I don’t believe he is seeing 2 totally separate identical posters
Then it is working as expected and I don’t see what the problem is.
If you have more than one version of a movie, the number of versions appears as a number on the movie poster.
This is the regular way in Plex.
Unless you ā€˜split’ the movie.
https://support.plex.tv/articles/201018248-merge-or-split-items/
I ā€œthinkā€ his grievance is disambiguating a ā€œduplicateā€ movie (with a different file name more than just the quality) vs a ā€œduplicateā€ version (same file name except the quality).
An idea:
Here is what can lead to separate posters:
The older version was already for a while in the library.
then the default metadata agent for the library was changed (ā€˜Plex Movie’ vs. ā€˜TheMovieDatabase’)
When the second version was added, it got matched to the other metadata agent. Plex then doesn’t know it is the same movie.
You can confirm this suspicion by looking at the Plex XML info of the two duplicates/posters.
If they have different content in the guid= property, it probably happened like I described.
Exactly - Having multiple version of the same movie in different qualities - SHOULD NOT BE LISTED AS A DUPLICATE!
When I have movies that are duplicates they are doubles in different folders but for some reason are the same movie - like IMDB and MOVIE DB doesn’t always have the same release year so this is a perfect tool to clean up duplicates.
imagine having 600 movies with different qualities versions (Each movie in the same folder) and then having 5 duplicates in different folders, how do you disquenties them from the 600 others, when they all are listed as ā€œDuplicatesā€ ARGHH! following the naming rules they should not be listed as a duplicates
@casperse Looks like while i understand your issue, it is a ā€œFeature requestā€ at best as what its doing is what it is designed to do per @ā€œMovieFan.Plexā€. Atleast you know now!
If you are comfortable at any scripting language you could write something pretty easily to parse this out on the backend :slight_smile:
Good luck!
The filename has nothing to do with the files being duplicates. The filename is only used to help in matching the file to the movie from IMDB/TMDB. If multiple files are matched to the same movie in the same library, they become a duplicate. If you don’t want duplicates, but want to see multiple different entries, you can split these after they are combined.
I’m not clear why you would want this. Are you just looking for a way so you can pick the one version you want to play You can do that with duplicates. Most Plex clients have the option to ā€œPlay Versionā€ which allows you to choose.
He knows they are duplicates. He wants to use Duplicates as a way to find incorrectly matched movies, and version to play another version. To do that without sorting through lots of information he wants the duplicate number that shows on the corner of the poster to only show if its incorrectly matched but not show if there are multiple versions of correctly matched media. The only way that could be done is with the filename. As plex only uses the filename for IMDB/TMDB parsing, its not currently an option.
Ok. But how would PMS know something is incorrectly matched? The filename must have had something that allowed them to be matched to the same movie. If the matching is wrong we can look at this, but there still isn’t a way to identify a mismatch.
