Multiple versions shows up as duplicates?
It would have to be very strict based on naming convention.
The best - by far - example i can give you is a movie that I have that marks as a duplicate that is incorrectly matched with proper naming convention.
/mnt/movies/The.Hunger.Games.Mockingjay.Part.1.(2014)
/mnt/movies/The.Hunger.Games.Mockingjay.Part.1.(2014)/The.Hunger.Games.Mockingjay.Part.1.(2014).Remux-1080p.mkv
/mnt/movies/The.Hunger.Games.Mockingjay.Part.2.(2015)
/mnt/movies/The.Hunger.Games.Mockingjay.Part.2.(2015)/The.Hunger.Games.Mockingjay.Part.2.(2015).Bluray-1080p.mkv
This has 2 totally separate years, yet it marks them both as the first movie. It would be identified by a difference in year.
That doesn’t follow the guideline, exactly. The guide is
Movie Name (year) - optional.extension
I don’t know if the periods and the extra remux/bluray text are confusing it. I’d have to see the scanner logs to check. I use the following and they matched separately for me.
The Hunger Games Mockingjay Part 1 (2014)\The Hunger Games Mockingjay Part 1 (2014) [1080p].mp4
The Hunger Games Mockingjay Part 2 (2015)\The Hunger Games Mockingjay Part 2 (2015) [1080p].mp4
Periods vs Spaces shouldnt be a parsing problem id hope… thats just a preference because i manage everything over a terminal and having to \ every space until my tab completion is unique is a PITA haha. As for specifying the type of quality remux/bluray i assume if thats in [] with the quality itself it wont make a difference. Ive seen you post about brackets before but if it really completely ignores it, i think, it should be added to the https://support.plex.tv/articles/200381023-naming-movie-files/ section.
@dirtycajunrice said:
Periods vs Spaces shouldnt be a parsing problem id hope… thats just a preference because i manage everything over a terminal and having to \ every space until my tab completion is unique is a PITA haha. As for specifying the type of quality remux/bluray i assume if thats in with the quality itself it wont make a difference. Ive seen you post about brackets before but if it really completely ignores it, i think, it should be added to the https://support.plex.tv/articles/200381023-naming-movie-files/ section.
I’m not sure what the problem is. I’ll have to test it. The bracket thing is optional and shouldn’t be needed if you follow the naming guide correctly. In your case, you don’t have the dash after the year. You actually have the text remux and bluray which could be throwing off the matching result.
Also, the official title of the movie is:
The Hunger Games: Mockingjay - Part 1
The colon and dash in the official title often impact matching results, even when the year is specified. Again, I won’t know until I test. This is just a matching issue and nothing to do with duplicates.
but incorrect duplicates are 100% because of matching issues. Thats his entire goal. To use Duplicates as a ā€œMismatchedā€ finder and have the function of duplicates be moved only into the Version info.
Yes, but how would a computer know the difference between a duplicate and versions of the same file. In it’s mind, all matches are correct and versions of the same movie.
I understand the parallelism, I just have the opinion that with stricter regex you could possibly separate the functions
