File Naming Structure for 4 versions of the same movie
Hi All,
I just discovered plex and I am now ripping our DVD collection after setting up a Plex server on an old laptop. Everything is great and the forums have been an incredible source of information. I have just run into a minor file naming issue I hope you can help me resolve.
My DVD if Scrooge (1951) has 4 versions of the movie B&W 4x3 B&W 16x9 Colorized 4x3 Colorized 16x9
What is the best file structure to have each item show up in the plex menu? Example 1
  • Scrooge (1951)-B&W 4x3
  • Scrooge (1951)-B&W 16x9
  • Scrooge (1951)-Colorized 4x3
  • Scrooge (1951)-Colorized 16x9
Or Example 2
  • Scrooge (1951)
  • **Scrooge (1951)-B&W 4x3
  • **Scrooge (1951)-B&W 16x9
  • **Scrooge (1951)-Colorized 4x3
  • ** Scrooge (1951)-Colorized 16x9
or is there some other way of doing it?
Should I drop all the bonus material (trailers etc.) in the main folder or in each subfolder if example 2 is the way to go?
Thank you in advance!
You got the right idea but name them,
  • Scrooge (1951) [B&W 4x3]
  • Scrooge (1951) [B&W 16x9]
  • Scrooge (1951) [Colorized 4x3]
  • Scrooge (1951) [Colorized 16x9]
Plex will of course see these as duplicates and group them together. You will then have to split apart then edit the titles to suit your naming needs.
I speak of example 1 I do not use sub folders for movies so I can’t say much on example 2
If I may: ask yourself if you really need 4 versions of the same movie, which are only minimally different. I’d try and store only a version which has the original aspect ratio.
You can tell your TV later to zoom into the picture if you don’t like the black borders on the sides.
Options man, options… We love them, lol… Though I for one would only keep the B&W and colorized versions. I like color and my mom likes the B&W.
Not any more…
Now everything named ‘correctly’ as you have it, will be added as a separate entity, all going along side by side in Recently Added if added at once, or each new ‘Version’ will.
Merge behavior altered… for whatever reason.
Only The Shadow Knows…
I knew there had to be something wrong with you and until just now I didn’t know what.
Out of the two people you mention - your Ma is the normal one…
:sunglasses:
Really? When did this happen?
lol, you truly have no idea. But consider yourself lucky not to know the extent, lol.
Hi JuiceWSA,
Just for clarification, the way I have the files named or the way NewPlaza suggested I name them?
BTW I’ve been using your guide (DVD Rip Quality on Plex/Roku Ultra - #12 by JuiceWSA) to rip my DVD’s thank you for providing it. Is there an updated version for Handbreak 1.1.0?
New Plaza named them correctly. [Brackets] should enclose non-compliant elements in a file name so Plex will ignore them.
‘The Guide’ is what it is.
It needs a re-write, but HB is still whacked out on DVD Anamorphic Settings and I’m not going to write a new Guide until HB fixes it.
