Music player "play speed" options too limited
Hi. I have a suggestion…
Under the “Play Speed” option, there should be more speed options to chose from.
The selectable speeds are too wide apart, which makes the music dialog go from normal to too fast speaking. The current options go from 1.0x to 1.1x. I feel that this is too limited. The increments are too far apart. Making this feature almost unusable.
It would be great to have more speed options. Which gives us more speeds to chose from, between the increments 1.0x and 1.1x
For instance, in some other music players after the 1.0x speed option they also have the option to pick speed: 1.01x, 1.02x, 1.03x, 1.04x, etc
It would be great if these speed options are here too. Because the speed 1.1x is too fast to be use to listen as normal music dialog.
I am a music fanatic, and my personal sweet spot is the speed 1.02x. A lot of professional DJs agree with me. It gives the music listening experience a more “ideal” listening enjoyment!
Thank you :blush:
