After playing the first tract from the playlist, it plays the next tract from the album of the first tract. From there, it continues playing tracts from that same album. Problem does not exist on WIN10 and iOS devices. Workaround is to use iPhone to cast to Shield. Been a problem for many months, just getting around trying to find a solution.
I finally figured out that when using the Nvidia Shield TV remote, only using the position dial and the enter within Plex’s controls (previous, next, stop, run etc) give expected results. Using the other buttons on the remote can be a problem.
