Music playlists not displaying
When viewing music playlists from the RECOMMENDED | LIBRARY | PLAYLISTS bar at the top of the Music library, it just shows my library. RECOMMENDED and LIBRARY both work fine, but playlists shows the exact same thing as LIBRARY. See below:
RECOMMENDED :white_check_mark:
LIBRARY :white_check_mark:
PLAYLISTS :x:
To see my music playlists, I have to go to the Playlists library specifically:
Does anyone know why this is happening? It was working fine a few weeks ago. My PMS is updated and I’ve tried stopping and restarting PMS on my Synology NAS, neither worked.
I’ve seen this with some users and their collections tab.
Settings > Plex Web > Debug > Restore Defaults did the trick for those users. Keep in mind this will reset the Plex Web configuration (not your server).
Thank you so much, that worked.
