I am using an Imac to serve plex media stored on a USB drive. The Mac is set not to sleep so it is always available for client connections. When I select something in a client, it will show the info page but when I hit play it always shows an error with a ‘retry’ button. The retry always works. The setting to ‘put hard drives to sleep when possible’ is off but the USB drives must be sleeping anyway. Is there any way to make the server wait a bit longer for the spin-up automatically instead of showing the error and only working on the retry?
Thanks, but I’m finding it very hard to picture any server operations that would be worse than unnecessarily throwing an error on a working drive. Can you elaborate on how waiting for the drive to work properly could be a bad thing? Plex is the only thing with this problem.
Yes, please change that timeout to either a longer duration or even better a different style.
On Android TV the error message even occurs before loading the preplay screen.
But it doesn’t make any sense at all that the whole preplay page doesn’t load if the media file is sleeping. EVERYTHING on that preplay page is stored in the Plex Database, so the drive could spinup in the background without problems.
