My channels are showing up wrong for my postal code in live EPG
Server Version#: 1.19
Tuner Make/Model: HDHomeRun Connect
Guide/Lineup name:
Using XMLTV?: No
Channel number/Name: Many
I’m getting really frustrated because I put in my postal code but it will not show the right channels available for my area. Is there a way I can just see all the over the air channels in Canada and pick what channels I am currently receiving?
I’m pretty frustrated that there isn’t even a way to contact Plex support about this, I can’t use the guide feature or live dvr because of this. I’ve tried playing around with different neighbouring postal codes to try and figure out it I can get it to show the channel but it will not show all the channels.
You can use this form here:
You can also try nearby postal codes and see if you find a better match for your physical lineup.
Yeah I’ve tried that as well, thanks for getting back to me. I will add that in, hopefully they can do something about it. I’m trying to move everything into Plex and not rely on anything else but its getting difficult with this issue.
