Server Version#:Truenas Goldeneye 25.10.3.1
Player Version#:1.3.10
When I try to play any media from my server I get the loading circle and that is it. Nothing plays, it just sits there thinking. Then the screen saver comes on. Here is my log from the server app. 2026-05-28 16:10:07.797041+00:00[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
2026-05-28 16:10:08.799217+00:00[s6-init] ensuring user provided files have correct perms…exited 0.
2026-05-28 16:10:08.800264+00:00[fix-attrs.d] applying ownership & permissions fixes…
2026-05-28 16:10:08.800952+00:00[fix-attrs.d] done.
2026-05-28 16:10:08.801624+00:00[cont-init.d] executing container initialization scripts…
2026-05-28 16:10:08.802849+00:00[cont-init.d] 40-plex-first-run: executing…
2026-05-28 16:10:13.977647+00:00Plex Media Server first run setup complete
2026-05-28 16:10:13.978472+00:00[cont-init.d] 40-plex-first-run: exited 0.
2026-05-28 16:10:13.979998+00:00[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: executing…
2026-05-28 16:10:14.727150+00:00[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: exited 0.
2026-05-28 16:10:14.728968+00:00[cont-init.d] 50-plex-update: executing…
2026-05-28 16:10:14.830274+00:00[cont-init.d] 50-plex-update: exited 0.
2026-05-28 16:10:14.830891+00:00[cont-init.d] done.
2026-05-28 16:10:14.831522+00:00[services.d] starting services
2026-05-28 16:10:14.853357+00:00Starting Plex Media Server.
2026-05-28 16:10:14.853403+00:00[services.d] done.
2026-05-28 16:10:27.632862+00:00Critical: libusb_init failed
Any ideas?
