Numbers in filenames appear to stop movies being scanned (if they appears early in name, or are not delimited from chars). Here some stuff I put together a few days ago:
http://forums.plexapp.com/index.php?/topic/16371-over-1000-movies-but-only-394-scanned/page__view__findpost__p__98128
http://forums.plexapp.com/index.php?/topic/16371-over-1000-movies-but-only-394-scanned/page__view__findpost__p__98232
I believe that they are skipped because the scanner believes it’s a TV show (some references in log files).
It only affected around 3-4 of my Movies, so the impact may not be big…
@hippojay if you want me on twitter…
Movie: Sherlock Holmes
Directory;
<br />
cbgb-sherlockholmes720.mkv<br />
cbgb-sherlockholmes720.nfo<br />
cbgb-sherlockholmes720.srt<br />
Log:
<br />
Sep 06, 2010 11:39:22 [0xa0558500] DEBUG - * Scanning directory /Users/<user>/Movies/Sherlock Holmes/Sherlock.Holmes.720p.Bluray.x264-CBGB<br />
Sep 06, 2010 11:39:22 [0xa0558500] DEBUG - * Taking directory 'Sherlock Holmes/Sherlock.Holmes.720p.Bluray.x264-CBGB' (510) out of the map (83 left)<br />
There seems to be a scanning problem with the show “Nip/Tuck”. My folder is called “Nip Tuck”. If I have a folder “Season 5” with the filename “Nip/Tuck - S05E01” in it, it doesn’t work. If the file is directly in “Season 5”, it works. Seems to be a problem with the “/”.
This file was ignored by the scanner:
/Volumes/Drobo/Video/TV Shows/Star Trek/Season 1/Star Trek - S01E28 - Griff in die Geschichte.mp4
But it worked when I moved it one folder higher (or lower?):
/Volumes/Drobo/Video/TV Shows/Star Trek/Star Trek - S01E28 - Griff in die Geschichte.mp4
Elan.. Don't know what you did, but I just updated to the latest 'updates' and now my TV Shows are all scanning metadata perfectly... Dude, you're a god... If only our Government gave service like you and the Plex team...
Look on the TVDB Site. The show as it is inputted into the TVDB is called Nip Tuck. so it should be TV\Nip Tuck\Season 5\Nip Tuck - S05E01. Try if that works.
your file structure is a little off it should be
try it again with shift + refreshing in the tv shows section of the plex media server after changing the directory structure and if it fails post the plex media server.log file
For those of you having trouble. Read the wiki post on plex 9 it includes a section on proper naming structure. Also take a look on IMDB or TVDB and make sure your TV show / movie matches exactly to the name that it has on its website.
Plexx did stop scanning after it found the filename “Dexter - S02E03 - Der düstere Begleiter.m4v” with the german umlaut in it. I removed the umlaut from the filename, but it still didn’t work. Then I also removed the umlaut from the Meta-tag in the file - and it worked!
for the afp nas issue on the blog, i’ve noticed that if i mount as guest, about 30-40% of the movies won’t get scanned in at all, where as if i mount as a user on the rwlist, it scans in 100% of the movies… i deleted the logs already to get the library back up and running, but it should br pretty straight forward to replicate. hope it helps.
Okay, I created sub-folder "/Volumes/Drobo/Video/TV Shows/Star Trek/Season 1/" and moved the file to it.
In "Plex Media Scanner.log" I always get lines like that:
<br />
Sep 06, 2010 15:01:13 [0xa08e8500] DEBUG - * Scanning directory /Volumes/Drobo/Video/TV Shows/Star Trek<br />
Sep 06, 2010 15:01:13 [0xa08e8500] DEBUG - * Taking directory 'Star Trek' (402) out of the map (16 left)<br />
In "Plex Media Server.log" I got nothing. I touched a file and got his:
<br />
Sep 06, 2010 15:00:16 [0xa08e8500] INFO - Library section 14 (TV Shows) will be updated because FSEvents detected a change in /Volumes/Drobo/Video/TV Shows/Star Trek/Season 1/<br />
Sep 06, 2010 15:00:16 [0xa08e8500] DEBUG - Requested that section 14 be updated, force=0<br />
Sep 06, 2010 15:00:16 [0xa08e8500] DEBUG - Queueing section 14<br />
Sep 06, 2010 15:00:16 [0xb1256000] DEBUG - Scanning section 14<br />
Sep 06, 2010 15:00:16 [0xb1256000] DEBUG - Killing job.<br />
Sep 06, 2010 15:00:16 [0xb1256000] DEBUG - Signalling job with 9<br />
Sep 06, 2010 15:00:16 [0xb1256000] DEBUG - Job running: /Users/oli/Library/Application Support/Plex/Plex Media Server.app/Contents/MacOS/Plex Media Scanner --scan --refresh --section 14 <br />
Sep 06, 2010 15:00:16 [0xa08e8500] INFO - Library section 14 (TV Shows) will be updated because FSEvents detected a change in /Volumes/Drobo/Video/TV Shows/Star Trek/<br />
20 seconds later:
<br />
Sep 06, 2010 15:00:36 [0xa08e8500] INFO - Library section 14 (TV Shows) will be updated because FSEvents detected a change in /Volumes/Drobo/Video/TV Shows/Star Trek/<br />
Sep 06, 2010 15:00:36 [0xa08e8500] DEBUG - Requested that section 14 be updated, force=0<br />
Sep 06, 2010 15:00:36 [0xa08e8500] DEBUG - Section 14 is already being updated.<br />
Sep 06, 2010 15:00:36 [0xb07b7000] ERROR - Error issuing curl_easy_perform(handle): 22<br />
Then I moved the file back from to /Volumes/Drobo/Video/TV Shows/Star Trek/ (without the season-folder) and had success:
<br />
Sep 06, 2010 15:08:55 [0xa08e8500] DEBUG - * Scanning directory /Volumes/Drobo/Video/TV Shows/Star Trek<br />
Sep 06, 2010 15:08:55 [0xa08e8500] DEBUG - * Taking directory 'Star Trek' (402) out of the map (16 left)<br />
Sep 06, 2010 15:08:55 [0xa08e8500] DEBUG - * Scanning Star Trek Season 1 Episode 7<br />
Sep 06, 2010 15:08:55 [0xa08e8500] DEBUG - Looking for path match for [/Volumes/Drobo/Video/TV Shows/Star Trek/Star Trek - S01E07 - Der alte Traum.mp4]<br />
Sep 06, 2010 15:08:55 [0xa08e8500] DEBUG - Skipping hash check, no size match for 1369695458 bytes.<br />
Sep 06, 2010 15:08:55 [0xa08e8500] DEBUG - No match for hash.<br />
Sep 06, 2010 15:08:55 [0xa08e8500] DEBUG - Checking descendants of Star Trek<br />
Sep 06, 2010 15:08:55 [0xa08e8500] DEBUG - Creating show 'Star Trek'<br />
Sep 06, 2010 15:08:55 [0xa08e8500] DEBUG - Added new metadata item (Star Trek) with ID 3832<br />
Sep 06, 2010 15:08:55 [0xa08e8500] DEBUG - Creating season 1 for show 'Star Trek'<br />
[quote name=‘icorn’ date=‘06 September 2010 - 07:14 AM’ timestamp=‘1283778872’ post=‘102366’]
Okay, I created sub-folder “/Volumes/Drobo/Video/TV Shows/Star Trek/Season 1/” and moved the file to it.
In “Plex Media Scanner.log” I always get lines like that:
[font=“Verdana, arial, sans-serif”][size=“3”][size=3]
[/size][/size][/font]
[font=“Verdana, arial, sans-serif”][size=“3”][size=3]In the TVDB the title is different everything has to match the tvdb. Look up Star Trek on the TVDB and you will see that the name is different. try renaming the file Star Trek S01E28.avi and retry with hitting the shift button and the circular button on the lower right hand corner of plex media server.[/size][/size][/font]
[quote name=‘playstation87’ date=‘06 September 2010 - 04:14 PM’ timestamp=‘1283782488’ post=‘102414’]
Well, since it works if I don't use the "Season"-folders, I will just leave it like that.
Still strange, that other shows work, even if I have the german episode names in the filename after the episode number.
After scanning 3 times (after each pass I trashed the DB, since there where too many errors) my Movie Collection, I finally managed to have all of the movies correctly identified.
By doing so, I come across a couple of bugs:
The first one is involving the “poster” plugin and movies with a number as title that already have a pic with the same name in the same directory: i.e. 9.avi and 9.jpg, or 2012.mkv and 2012.jpg.
If both files are inside the same directory, all of the movies in that directory will have that picture at default poster!
I tryed 2 times, each time all of the movies had the pic as poster; then I deleted the DB and relaunched Plex after removing the pic, now all of the movies have the right poster.
the second one is a know bug: many posters aren’t loading correctly and the menu shows a grayed “plex” icon.
It seems to me it’s not a random problem: the movies/pic that show problems are qute always the same (I made 5-6 rescan).
Although the movies where correctly identified and linked to IMDB metadata and the posters thumbnail are shown in “customize” menu, some posters and backgrounds give an error in downloading.
In one on my attempt, log showed:
“Sep 06, 2010 17:55:40 [0xb1047000] WARN - Error issuing request to: http://hwcdn.themoviedb.org/posters/adb/4bc978d6017a3c57fe037adb/avatar-creating-the-world-of-pandora-original.jpg (22)
Sep 06, 2010 17:55:40 [0xb1047000] DEBUG - Obtained 0 bytes from http://hwcdn.themoviedb.org/posters/adb/4bc978d6017a3c57fe037adb/avatar-creating-the-world-of-pandora-original.jpg”
One last thing:
The poster and metadata plugin give slightly different results each time they run…
I.E.: I remember the first 2 times i run the scan, the “Avatar: Creating the world of Pandora” poster was showing correctly…
And also, the number of pics I could select the poster from is different each time…
Ya that is weird if others worked but that doesn't. Too bad I couldn't have been more help. Bug hunting and finding is a tricky business that I'll leave to the very capable hands of the developers.
I’m trying to reproduce this issue, but of course a fake file isn’t working (as I suspect the metadata inside the MP4 file is causing it. Can anyone please, please please upload a file for me and email me a link?
Thanks!
file uploaded and email sent.
What file do you mean? I can sent you a file with umlauts in the metadata title, that stops scanning.
I’m having issues with my TV shows showing up. All but one don’t appear.
All of my shows are named using the same convention, “S01E01 Name”.
The show that shows up isn’t the first in the folder, it’s completely random.
Forgot the path.
This is a working episode: /Volumes/Media/Videos/TV Shows/Cowboy Bebop/S01E01 Asteroid Blues.m4v
One of the (many) non working episodes looks like this: /Volumes/Media/Videos/TV Shows/Firefly/S01E01 Serenity.m4v
So for ages under plex 8, ive always named my Tv Shows, BLAH 101, 102 etc, and just named the TV Show Folder, ive never bothered with season sub-folders. I like to keep things short and simple.
When i first installed plex 9, all my shows showed up, but now, after discovering some shows had vanished ( not the info the actual shows), it seems to only like the fact, and update all the info, adding the appropriate season folders.
Im not bitching, mearly offering what might be helpful for some people, im slowly going through adding season folders, i have 113 shows, not sure why i keep them, ill hardly ever watch most of them again.
Im very impressed with the live updating of folders, awesomeness. and love the shared library, something ive been wanting for ages.
Happy to help with any bug finding or whatever you want. although im patient, but not too savvy.
[twitter]@keepitwarm[/twitter]
