Lots of bug-fixes for scanners pushed, you will get them via auto-updates. Details here: http://pastie.org/1143338
It works great! Now accepts also the funny german umlauts in the metadata. Thanks alot!
Awesome piece of software Elan… sorry for all the negative energy around!
So - the file counter in PMS says 125 movies, whereas Finder tells me that I have 126. After much rooting around, I found the culprit is Lord of the Rings 3 (Return of the King).
Here are the relevant extracts from PMS Scanner.log. It appears to be getting matched to the Fellowship of the Rings
08:25:46 [0xa0ad74e0] DEBUG - * Scanning directory /Volumes/Public/Media/Movies/Lord Of The Rings - Return Of The King<br />
Sep 07, 2010 08:25:47 [0xa0ad74e0] DEBUG - * Taking directory 'Lord Of The Rings - Return Of The King' (428) out of the map (197 left)<br />
Sep 07, 2010 08:25:47 [0xa0ad74e0] DEBUG - * Scanning Lord of the Rings Return of the King<br />
Sep 07, 2010 08:25:47 [0xa0ad74e0] DEBUG - Looking for path match for [/Volumes/Public/Media/Movies/Lord Of The Rings - Return Of The King/Lord of the Rings - Return of the King.mp4]<br />
Sep 07, 2010 08:25:47 [0xa0ad74e0] DEBUG - Checking by hash to see if we can find a match with 5717b6a1a486464ff6da3ce9edef6a11da6741bb (display offset: 0, not part -1)<br />
Sep 07, 2010 08:25:47 [0xa0ad74e0] DEBUG - We found a hash match for [/Volumes/Public/Media/Movies/Lord Of The Rings - Return Of The King/Lord of the Rings - Return of the King.mp4] which was [/Volumes/Public/Media/Movies/Lord Of The Rings - The Fellowship Of the Ring/Lord of the Rings - The Fellowship of the Ring.mp4].<br />
Sep 07, 2010 08:25:47 [0xa0ad74e0] WARN - Duplicate media part detected [/Volumes/Public/Media/Movies/Lord Of The Rings - The Fellowship Of the Ring/Lord of the Rings - The Fellowship of the Ring.mp4], ignoring.<br />
Sep 07, 2010 08:25:47 [0xa0ad74e0] DEBUG - Hint name didn't match ('Lord of the Rings Return of the King' != 'Lord of the Rings the Fellowship of the Ring') for DB media item 8<br />
Sep 07, 2010
I checked IMDB and noted that strictly speaking it is "THE Lord of the Rings - THE Return of the King", but after renaming/ rescanning, still no joy.
Thanks so much for any help - let me know if you need any more information!
Chris
Hi
My case is a bit different. I have all my TvShows this way:
Doctor Who/Season 1/S01E01/Doctor_Who_S01E01.avi
Inside S01E01 directory I have the video file and subtitles.
This structure worked fine with plex 0.8.
Now it seems it works only depending on the TV show.
For example, with Doctor Who it works fine. But, with Caprica or Dexter there is no way to do it.
It only worked once I move the video files inside Season 1. For example:
Caprica/Season 1/Caprica_S01E01.avi
Regards
OK, did a bit more tracking of this one, if only to understand python a bit more.
Anyway, the filename is avs720-p.mkv, and it's failing because it thinks it's a TV episode. It's failing at "Plex Movie Scanner.py" line 81.
This is checking against a regex in the SeriesScanner. The exact regex it fails on is (from "Plex Series Scanner.py" Line 10:
'(.*?)[sS](?P[0-9]+)[\._\- ]*(?P[0-9]+)', # S03-03
So avs720-p.mkv matches because "s720" appears and the scanner thinks it a TV show. Now, it's possible to fix this by altering the [\._\-]* to [\._\-]+ which would require a '.', '_' or '-' to appear and would only match series of tyep s01-03, s199.300, S23_21, etc..
How many TV series have number like sXXXXX? Is "S101" series 1 ep 10 or Series 10 ep 1? Or, for scanning dirs designated as Movies, we don't use this regex (not 100% sure why we are looking for Tv in a movie dirs, belts and braces?)
This update fixed the issue I was having with single songs within albums not being found, thanks!
How to handle different shows that have similar names like:
Wallander
Wallander (UK)
(Right now only Wallander is showing up)
Following is just a note right now as I know there is only english language support - How to handle episodes in different languages for the same show, including different name per language, like:
Komissar Wallander / Season 1 /
Wallander (UK) / Season 2 /
What if the name is the same for different languages, but the season language is different (until now I could create different structures per language and it worked for Plex8), for example:
Show (DE) / Season 1 /
Show / Season 2 /
Until now I had 3 different folders
Wallander
Komissar Wallander
Wallander (UK)
and all was ok with Plex8, but now only Wallander shows up!
How to handle main and extras DVD?
Until now I could name it like
Rush - R30 (2005)
Rush - R30 Disc 2 (2005)
And it worked under Plex8, now the second disc is gone, how to do now? Where is it?
My TV shows are working great… but my home movies I can’t get to scan. I set it up like below.
In the log I see the following for all movies that have dates in them (with the dashes in the dates).
9/7/10 4:47:32 PM [0x0-0x62c62c].com.plexapp.plexmediaserver[11867] The file 2010-05-27 002.mp4 looked like a date-based TV show so we’re skipping it.
9/7/10 4:47:32 PM [0x0-0x62c62c].com.plexapp.plexmediaserver[11867] The file 2010-06-03 010.mp4 looked like a date-based TV show so we’re skipping it.
9/7/10 4:47:32 PM [0x0-0x62c62c].com.plexapp.plexmediaserver[11867] The file 2010-06-03 011.mp4 looked like a date-based TV show so we’re skipping it.
9/7/10 4:47:32 PM [0x0-0x62c62c].com.plexapp.plexmediaserver[11867] The file 2010-06-05 011.mp4 looked like a date-based TV show so we’re skipping it.
9/7/10 4:47:32 PM [0x0-0x62c62c].com.plexapp.plexmediaserver[11867] The file 2010-06-05 alex at pixie woods.wmv looked like a date-based TV show so we’re skipping it.
9/7/10 4:47:32 PM [0x0-0x62c62c].com.plexapp.plexmediaserver[11867] The file 2010-06-24 002.mov looked like a date-based TV show so we’re skipping it.
9/7/10 4:47:32 PM [0x0-0x62c62c].com.plexapp.plexmediaserver[11867] The file 2010-06-26 002.mov looked like a date-based TV show so we’re skipping it.
9/7/10 4:47:32 PM [0x0-0x62c62c].com.plexapp.plexmediaserver[11867] The file 2010-07-01 001.mov looked like a date-based TV show so we’re skipping it.
I’m having a problem with one movie where I have both the theatrical and director’s cuts, and the Scanner appears to be deleting the reference to the director’s cut, or combining it with the theatrical movie.
Sep 07, 2010 18:38:35 [0xa08c0500] DEBUG - Updating metadata item (Terminator Salvation Director’s Cut) with ID 5761
Sep 07, 2010 18:38:35 [0xa08c0500] DEBUG - We found a matching item (5760) by GUID for ‘Terminator Salvation Director’s Cut’, moving over 1 media items.
Sep 07, 2010 18:38:35 [0xa08c0500] DEBUG - Updating part with ID=5606 [/Users/plex/Movies/Terminator Salvation (Director’s Cut)/Terminator Salvation (Director’s Cut).m4v]
Sep 07, 2010 18:38:35 [0xa08c0500] DEBUG - Destroying metadata item 5761 (Terminator Salvation Director’s Cut)
I am still seeing failures on the following:
No Metadata & Incorrect picture
Jamie Eat To Save Your Life
Metadata & Incorrect Picture
City Lights (1987) - Is showing the 1986 version picture
No Metadata and No Poster
Jamie’s Great Italian Escape
Pukka Tukka
Correct Metadata Incorrect Poster
Clash Of The Santas
I have tried everything and when I click Fix Incorrect Match it doesn’t find anything even though these are clearly available on the true TVDB website.
Here’s my contribution to the list of problems:
http://forums.plexapp.com/index.php?/topic/16414-music-tagging-gone-wrong/
http://forums.plexapp.com/index.php?/topic/16418-music-tagging-gone-wrong-pt2/
http://forums.plexapp.com/index.php?/topic/16424-music-tagging-gone-wrong-pt3/
Another problem that I have is: how do I deal with DVD extras. E.g. for David Attenboroughs “Life in the undergrowth” I have all the episodes and one extra (an interview). How shall I name this to show up? I mean if there are 5 episodes and an interview extra it would be plain wrong to name the interview as 6th episode. Any ideas how to proceed?
EDIT: This actually seems to be the solution (to name it S01E06): http://thetvdb.com/?tab=episode&seriesid=79185&seasonid=16174&id=304880&lid=7
But the issue remains for movies which come with extras.
Good luck squashing bugs.
The problem I’m having is with Star Trek New Voyages - Phase II. The initial scan thought it was TNG, but it certainly is not. While I figure there should be some issue as I have it set up for stacking, but Plex doesn’t stack TV shows. It no longer thinks it’s TNG, but there is none of the fancy metadata.
Full path is /Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - * Scanning directory /Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - * Taking directory 'Star Trek New Voyages - Phase II' (288) out of the map (9 left)<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - * Scanning Star Trek New Voyages Phase Ii Season 1 Episode 404<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - Looking for path match for [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/404_med_BLOOD_AND_FIRE_pt1.mp4]<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - Checking by hash to see if we can find a match with d13ecef156d64111af9fb90fc82414e407bb1da6 (display offset: 0, not part -1)<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - We found a hash match for [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/404_med_BLOOD_AND_FIRE_pt1.mp4] which was [/Volumes/Media Drive 02/TV/Star Trek - The New Voyages/404_med_BLOOD_AND_FIRE_pt1.mp4].<br />
Sep 08, 2010 03:34:13 [0xa0232720] INFO - Part rename detected [/Volumes/Media Drive 02/TV/Star Trek - The New Voyages/404_med_BLOOD_AND_FIRE_pt1.mp4] was renamed [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/404_med_BLOOD_AND_FIRE_pt1.mp4]<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - Hint show didn't match ('Star Trek New Voyages Phase Ii' != 'Star Trek the New Voyages') for DB media item 542<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - Checking descendants of Star Trek New Voyages - Phase II<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - Creating show 'Star Trek New Voyages Phase Ii'<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - Added new metadata item (Star Trek New Voyages Phase Ii) with ID 712<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - Creating season 1 for show 'Star Trek New Voyages Phase Ii'<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - Added new metadata item () with ID 713<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - Added new metadata item () with ID 714<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - Added new media item with ID=638 (episode=404&season=1&show=Star%20Trek%20New%20Voyages%20Phase%20Ii)<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - Added new media part with ID=639 [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/404_med_BLOOD_AND_FIRE_pt1.mp4]<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - * Scanning Star Trek New Voyages Phase Ii Season 1 Episode 2<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - Looking for path match for [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e02-1.wmv]<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - Checking by hash to see if we can find a match with ccde63954bee37a9ca82a2bb378d413e9a0044d4 (display offset: 0, not part -1)<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - We found a hash match for [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e02-1.wmv] which was [/Volumes/Media Drive 02/TV/Star Trek - The New Voyages/ST-TNV - s01e02-1.wmv].<br />
Sep 08, 2010 03:34:13 [0xa0232720] INFO - Part rename detected [/Volumes/Media Drive 02/TV/Star Trek - The New Voyages/ST-TNV - s01e02-1.wmv] was renamed [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e02-1.wmv]<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - Hint show didn't match ('Star Trek New Voyages Phase Ii' != 'Star Trek the New Voyages') for DB media item 543<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - -> FOUND metadata item (show)<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - -> We found a local media item with rooted metadata in Star Trek New Voyages - Phase II<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - Found existing show 712<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - Added new metadata item () with ID 715<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - Added new media item with ID=639 (episode=2&season=1&show=Star%20Trek%20New%20Voyages%20Phase%20Ii)<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - Added new media part with ID=640 [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e02-1.wmv]<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - Looking for path match for [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e02-2.wmv]<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - Checking by hash to see if we can find a match with 2c987aaa877186a4b830a2d3bce02c68683ab70b (display offset: 0, not part -1)<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - We found a hash match for [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e02-2.wmv] which was [/Volumes/Media Drive 02/TV/Star Trek - The New Voyages/ST-TNV - s01e02-2.wmv].<br />
Sep 08, 2010 03:34:13 [0xa0232720] INFO - Part rename detected [/Volumes/Media Drive 02/TV/Star Trek - The New Voyages/ST-TNV - s01e02-2.wmv] was renamed [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e02-2.wmv]<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - Hint show didn't match ('Star Trek New Voyages Phase Ii' != 'Star Trek the New Voyages') for DB media item 544<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - Found existing episode 2, will reuse it.<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - Updating metadata item () with ID 715<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - Added new media item with ID=640 (episode=2&season=1&show=Star%20Trek%20New%20Voyages%20Phase%20Ii)<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - Added new media part with ID=641 [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e02-2.wmv]<br />
Sep 08, 2010 03:34:13 [0xa0232720] DEBUG - Looking for path match for [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e02-3.wmv]<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - Checking by hash to see if we can find a match with f26b411d84c68acd13ec29de4cd7eb75758eafe2 (display offset: 0, not part -1)<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - We found a hash match for [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e02-3.wmv] which was [/Volumes/Media Drive 02/TV/Star Trek - The New Voyages/ST-TNV - s01e02-3.wmv].<br />
Sep 08, 2010 03:34:14 [0xa0232720] INFO - Part rename detected [/Volumes/Media Drive 02/TV/Star Trek - The New Voyages/ST-TNV - s01e02-3.wmv] was renamed [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e02-3.wmv]<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - Hint show didn't match ('Star Trek New Voyages Phase Ii' != 'Star Trek the New Voyages') for DB media item 545<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - Checking descendants of Star Trek New Voyages - Phase II<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - -> FOUND metadata item (show)<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - -> We found a local media item with rooted metadata in Star Trek New Voyages - Phase II<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - Found existing show 712<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - Found existing episode 2, will reuse it.<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - Updating metadata item () with ID 715<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - Added new media item with ID=641 (episode=2&season=1&show=Star%20Trek%20New%20Voyages%20Phase%20Ii)<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - Added new media part with ID=642 [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e02-3.wmv]<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - * Scanning Star Trek New Voyages Phase Ii Season 1 Episode 2<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - Looking for path match for [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e02-4.wmv]<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - Checking by hash to see if we can find a match with cdd976a3eb4b2cb6aafa7e7f670d37782485aafc (display offset: 0, not part -1)<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - We found a hash match for [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e02-4.wmv] which was [/Volumes/Media Drive 02/TV/Star Trek - The New Voyages/ST-TNV - s01e02-4.wmv].<br />
Sep 08, 2010 03:34:14 [0xa0232720] INFO - Part rename detected [/Volumes/Media Drive 02/TV/Star Trek - The New Voyages/ST-TNV - s01e02-4.wmv] was renamed [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e02-4.wmv]<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - Hint show didn't match ('Star Trek New Voyages Phase Ii' != 'Star Trek the New Voyages') for DB media item 546<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - Added new media item with ID=642 (episode=2&season=1&show=Star%20Trek%20New%20Voyages%20Phase%20Ii)<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - Added new media part with ID=643 [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e02-4.wmv]<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - Looking for path match for [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e02-5.wmv]<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - Checking by hash to see if we can find a match with 1122fbd56bfe7e53086f15a410badb1184707f5d (display offset: 0, not part -1)<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - We found a hash match for [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e02-5.wmv] which was [/Volumes/Media Drive 02/TV/Star Trek - The New Voyages/ST-TNV - s01e02-5.wmv].<br />
Sep 08, 2010 03:34:14 [0xa0232720] INFO - Part rename detected [/Volumes/Media Drive 02/TV/Star Trek - The New Voyages/ST-TNV - s01e02-5.wmv] was renamed [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e02-5.wmv]<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - Hint show didn't match ('Star Trek New Voyages Phase Ii' != 'Star Trek the New Voyages') for DB media item 547<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - Added new media item with ID=643 (episode=2&season=1&show=Star%20Trek%20New%20Voyages%20Phase%20Ii)<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - Added new media part with ID=644 [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e02-5.wmv]<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - * Scanning Star Trek New Voyages Phase Ii Season 1 Episode 3<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - Looking for path match for [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e03.mp4]<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - Checking by hash to see if we can find a match with 28a884e3bdaf315d201727020dc1e35b3cee5af2 (display offset: 0, not part -1)<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - We found a hash match for [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e03.mp4] which was [/Volumes/Media Drive 02/TV/Star Trek - The New Voyages/ST-TNV - s01e03.mp4].<br />
Sep 08, 2010 03:34:14 [0xa0232720] INFO - Part rename detected [/Volumes/Media Drive 02/TV/Star Trek - The New Voyages/ST-TNV - s01e03.mp4] was renamed [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e03.mp4]<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - Hint show didn't match ('Star Trek New Voyages Phase Ii' != 'Star Trek the New Voyages') for DB media item 548<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - Added new metadata item () with ID 716<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - Added new media item with ID=644 (episode=3&season=1&show=Star%20Trek%20New%20Voyages%20Phase%20Ii)<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - Added new media part with ID=645 [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e03.mp4]<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - * Scanning Star Trek New Voyages Phase Ii Season 1 Episode 4<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - Looking for path match for [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e04.mp4]<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - Checking by hash to see if we can find a match with 1e0f6e1b5d0f6eae44be663cbc458ed6bb82018c (display offset: 0, not part -1)<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - We found a hash match for [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e04.mp4] which was [/Volumes/Media Drive 02/TV/Star Trek - The New Voyages/ST-TNV - s01e04.mp4].<br />
Sep 08, 2010 03:34:14 [0xa0232720] INFO - Part rename detected [/Volumes/Media Drive 02/TV/Star Trek - The New Voyages/ST-TNV - s01e04.mp4] was renamed [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e04.mp4]<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - Hint show didn't match ('Star Trek New Voyages Phase Ii' != 'Star Trek the New Voyages') for DB media item 549<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - Added new metadata item () with ID 717<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - Added new media item with ID=645 (episode=4&season=1&show=Star%20Trek%20New%20Voyages%20Phase%20Ii)<br />
Sep 08, 2010 03:34:14 [0xa0232720] DEBUG - Added new media part with ID=646 [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e04.mp4]<br />
Sep 08, 2010 03:34:15 [0xa0232720] DEBUG - Whacking 8 media items that were left.<br />
Sep 08, 2010 03:34:15 [0xa0232720] DEBUG - Whacking media item 542.<br />
Sep 08, 2010 03:34:15 [0xa0232720] DEBUG - Was connected to metadata item 600, count is now 0.<br />
Sep 08, 2010 03:34:15 [0xa0232720] DEBUG - Destroying metadata item 600 (Episode 404)<br />
Sep 08, 2010 03:34:15 [0xa0232720] DEBUG - Whacking media item 543.<br />
Sep 08, 2010 03:34:15 [0xa0232720] DEBUG - Was connected to metadata item 601, count is now 1.<br />
Sep 08, 2010 03:34:15 [0xa0232720] DEBUG - Whacking media item 544.<br />
Sep 08, 2010 03:34:15 [0xa0232720] DEBUG - Was connected to metadata item 601, count is now 0.<br />
Sep 08, 2010 03:34:15 [0xa0232720] DEBUG - Destroying metadata item 601 (Encounter at Farpoint (2))<br />
Sep 08, 2010 03:34:15 [0xa0232720] DEBUG - Whacking media item 545.<br />
Sep 08, 2010 03:34:15 [0xa0232720] WARN - Asked to destroy a non-existent metadata item 601<br />
Sep 08, 2010 03:34:15 [0xa0232720] DEBUG - Whacking media item 546.<br />
Sep 08, 2010 03:34:15 [0xa0232720] DEBUG - Whacking media item 547.<br />
Sep 08, 2010 03:34:15 [0xa0232720] DEBUG - Whacking media item 548.<br />
Sep 08, 2010 03:34:15 [0xa0232720] DEBUG - Was connected to metadata item 602, count is now 0.<br />
Sep 08, 2010 03:34:15 [0xa0232720] DEBUG - Destroying metadata item 602 (The Naked Now)<br />
Sep 08, 2010 03:34:15 [0xa0232720] DEBUG - Whacking media item 549.<br />
Sep 08, 2010 03:34:15 [0xa0232720] DEBUG - Was connected to metadata item 603, count is now 0.<br />
Sep 08, 2010 03:34:15 [0xa0232720] DEBUG - Destroying metadata item 603 (Code of Honor)<br />
Sep 08, 2010 03:34:15 [0xa0232720] DEBUG - Destroying metadata item 599 (Season 1)<br />
Sep 08, 2010 03:34:15 [0xa0232720] DEBUG - Destroying metadata item 598 (Star Trek: The Next Generation)<br />
Sep 08, 2010 03:34:15 [0xa0232720] DEBUG - Whacking 1 directories that were left.<br />
Sep 08, 2010 03:34:15 [0xa0232720] DEBUG - Deleting directory [Star Trek - The New Voyages] (279)<br />
Sep 08, 2010 03:34:15 [0xa0232720] DEBUG - Refreshing section 2 of type: 2<br />
Sep 08, 2010 03:34:15 [0xa0232720] DEBUG - Show 'Star Trek New Voyages Phase Ii' needs refreshing, no match yet.<br />
Sep 08, 2010 03:34:15 [0xa0232720] DEBUG - Most recent grandchild was episode 404<br />
Sep 08, 2010 03:34:15 [0xa0232720] DEBUG - Issuing search query: http://localhost:32400/system/agents/search?mediaType=2&id=712&identifier=com.plexapp.agents.thetvdb&duration=-1&filename=%252FVolumes%252FMedia%2520Drive%252002%252FTV%252FStar%2520Trek%2520New%2520Voyages%2520-%2520Phase%2520II%252F404_med_BLOOD_AND_FIRE_pt1%252Emp4&lang=en&openSubtitlesHash=d55148e97384a3fb&plexHash=d13ecef156d64111af9fb90fc82414e407bb1da6&episode=404&season=1&show=Star%20Trek%20New%20Voyages%20Phase%20Ii<br />
Sep 08, 2010 03:34:15 [0xb0081000] DEBUG - * 1122fbd56bfe7e53086f15a410badb1184707f5d [asf wmv2/wmav2] Duration: 1284000ms, 864x480 (1.800000) 29.970fps, bitrate=1383kbps, audio channels=2<br />
Sep 08, 2010 03:34:15 [0xb0081000] DEBUG - Updating media item 643, size=208029004, metadata_item_id=715<br />
Sep 08, 2010 03:34:15 [0xb0081000] DEBUG - Updating part with ID=644 [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e02-5.wmv]<br />
Sep 08, 2010 03:34:15 [0xb0081000] DEBUG - Updating metadata item () with ID 715<br />
Sep 08, 2010 03:34:15 [0xb0081000] DEBUG - * cdd976a3eb4b2cb6aafa7e7f670d37782485aafc [asf wmv2/wmav2] Duration: 862000ms, 864x480 (1.800000) 29.970fps, bitrate=1385kbps, audio channels=2<br />
Sep 08, 2010 03:34:15 [0xb0081000] DEBUG - Updating media item 642, size=146021408, metadata_item_id=715<br />
Sep 08, 2010 03:34:15 [0xb0081000] DEBUG - Updating part with ID=643 [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e02-4.wmv]<br />
Sep 08, 2010 03:34:15 [0xb0081000] DEBUG - * f26b411d84c68acd13ec29de4cd7eb75758eafe2 [asf wmv2/wmav2] Duration: 409000ms, 864x480 (1.800000) 29.970fps, bitrate=1385kbps, audio channels=2<br />
Sep 08, 2010 03:34:15 [0xb0081000] DEBUG - Updating media item 641, size=74701254, metadata_item_id=715<br />
Sep 08, 2010 03:34:15 [0xb0081000] DEBUG - Updating part with ID=642 [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e02-3.wmv]<br />
Sep 08, 2010 03:34:15 [0xb0081000] DEBUG - * 2c987aaa877186a4b830a2d3bce02c68683ab70b [asf wmv2/wmav2] Duration: 762000ms, 864x480 (1.800000) 30.000fps, bitrate=1385kbps, audio channels=2<br />
Sep 08, 2010 03:34:15 [0xb0081000] DEBUG - Updating media item 640, size=135075608, metadata_item_id=715<br />
Sep 08, 2010 03:34:15 [0xb0081000] DEBUG - Updating part with ID=641 [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e02-2.wmv]<br />
Sep 08, 2010 03:34:15 [0xb0081000] DEBUG - * ccde63954bee37a9ca82a2bb378d413e9a0044d4 [asf wmv2/wmav2] Duration: 266000ms, 864x480 (1.800000) 29.970fps, bitrate=1385kbps, audio channels=2<br />
Sep 08, 2010 03:34:15 [0xb0081000] DEBUG - Updating media item 639, size=43258680, metadata_item_id=715<br />
Sep 08, 2010 03:34:15 [0xb0081000] DEBUG - Updating part with ID=640 [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e02-1.wmv]<br />
Sep 08, 2010 03:34:15 [0xb0081000] DEBUG - * 28a884e3bdaf315d201727020dc1e35b3cee5af2 [mov,mp4,m4a,3gp,3g2,mj2 h264/aac] Duration: 3866000ms, 852x480 (1.775000) 23.976fps, bitrate=800kbps, audio channels=2<br />
Sep 08, 2010 03:34:15 [0xb0081000] DEBUG - Updating media item 644, size=386833500, metadata_item_id=716<br />
Sep 08, 2010 03:34:15 [0xb0081000] DEBUG - Updating part with ID=645 [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e03.mp4]<br />
Sep 08, 2010 03:34:15 [0xb0081000] DEBUG - Updating metadata item () with ID 716<br />
Sep 08, 2010 03:34:16 [0xb0081000] DEBUG - * 1e0f6e1b5d0f6eae44be663cbc458ed6bb82018c [mov,mp4,m4a,3gp,3g2,mj2 h264/aac] Duration: 2630000ms, 640x360 (1.777778) 24.000fps, bitrate=1268kbps, audio channels=2<br />
Sep 08, 2010 03:34:16 [0xb0081000] DEBUG - Updating media item 645, size=416969911, metadata_item_id=717<br />
Sep 08, 2010 03:34:16 [0xb0081000] DEBUG - Updating part with ID=646 [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e04.mp4]<br />
Sep 08, 2010 03:34:16 [0xb0081000] DEBUG - Updating metadata item () with ID 717<br />
Sep 08, 2010 03:34:16 [0xb0081000] DEBUG - * d13ecef156d64111af9fb90fc82414e407bb1da6 [mov,mp4,m4a,3gp,3g2,mj2 h264/aac] Duration: 2613000ms, 480x360 (1.333333) 29.970fps, bitrate=744kbps, audio channels=2<br />
Sep 08, 2010 03:34:16 [0xb0081000] DEBUG - Updating media item 638, size=243027133, metadata_item_id=714<br />
Sep 08, 2010 03:34:16 [0xb0081000] DEBUG - Updating part with ID=639 [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/404_med_BLOOD_AND_FIRE_pt1.mp4]<br />
Sep 08, 2010 03:34:16 [0xb0081000] DEBUG - Updating metadata item () with ID 714<br />
Sep 08, 2010 03:34:21 [0xa0232720] WARN - No matches for search.
At this point I had to do a forced shut down to get the mini to shut down. :blink:
Post restart correction attempt.
Sep 08, 2010 03:45:42 [0xa0232720] DEBUG - * Scanning directory /Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II<br />
Sep 08, 2010 03:45:42 [0xa0232720] DEBUG - * Taking directory 'Star Trek New Voyages - Phase II' (288) out of the map (8 left)<br />
Sep 08, 2010 03:45:42 [0xa0232720] DEBUG - * Scanning Star Trek New Voyages Phase Ii Season 1 Episode 404<br />
Sep 08, 2010 03:45:42 [0xa0232720] DEBUG - Looking for path match for [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/404_med_BLOOD_AND_FIRE_pt1.mp4]<br />
Sep 08, 2010 03:45:42 [0xa0232720] DEBUG - Path matched, we're reusing media item 638<br />
Sep 08, 2010 03:45:42 [0xa0232720] DEBUG - * Scanning Star Trek New Voyages Phase Ii Season 1 Episode 2<br />
Sep 08, 2010 03:45:42 [0xa0232720] DEBUG - Looking for path match for [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e02-1.wmv]<br />
Sep 08, 2010 03:45:42 [0xa0232720] DEBUG - Path matched, we're reusing media item 639<br />
Sep 08, 2010 03:45:42 [0xa0232720] DEBUG - Looking for path match for [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e02-2.wmv]<br />
Sep 08, 2010 03:45:42 [0xa0232720] DEBUG - Path matched, we're reusing media item 640<br />
Sep 08, 2010 03:45:42 [0xa0232720] DEBUG - Looking for path match for [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e02-3.wmv]<br />
Sep 08, 2010 03:45:42 [0xa0232720] DEBUG - Path matched, we're reusing media item 641<br />
Sep 08, 2010 03:45:42 [0xa0232720] DEBUG - Looking for path match for [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e02-4.wmv]<br />
Sep 08, 2010 03:45:42 [0xa0232720] DEBUG - Path matched, we're reusing media item 642<br />
Sep 08, 2010 03:45:42 [0xa0232720] DEBUG - Looking for path match for [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e02-5.wmv]<br />
Sep 08, 2010 03:45:42 [0xa0232720] DEBUG - Path matched, we're reusing media item 643<br />
Sep 08, 2010 03:45:42 [0xa0232720] DEBUG - * Scanning Star Trek New Voyages Phase Ii Season 1 Episode 3<br />
Sep 08, 2010 03:45:42 [0xa0232720] DEBUG - Looking for path match for [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e03.mp4]<br />
Sep 08, 2010 03:45:42 [0xa0232720] DEBUG - Path matched, we're reusing media item 644<br />
Sep 08, 2010 03:45:42 [0xa0232720] DEBUG - * Scanning Star Trek New Voyages Phase Ii Season 1 Episode 4<br />
Sep 08, 2010 03:45:42 [0xa0232720] DEBUG - Looking for path match for [/Volumes/Media Drive 02/TV/Star Trek New Voyages - Phase II/ST-TNV - s01e04.mp4]<br />
Sep 08, 2010 03:45:42 [0xa0232720] DEBUG - Path matched, we're reusing media item 645<br />
Sep 08, 2010 03:45:44 [0xa0232720] DEBUG - Show 'Star Trek New Voyages Phase Ii' needs refreshing, no match yet.<br />
Sep 08, 2010 03:45:44 [0xa0232720] DEBUG - Most recent grandchild was episode 404<br />
Sep 08, 2010 03:45:44 [0xa0232720] DEBUG - Issuing search query: http://localhost:32400/system/agents/search?mediaType=2&id=712&identifier=com.plexapp.agents.thetvdb&duration=2613000&filename=%252FVolumes%252FMedia%2520Drive%252002%252FTV%252FStar%2520Trek%2520New%2520Voyages%2520-%2520Phase%2520II%252F404_med_BLOOD_AND_FIRE_pt1%252Emp4&lang=en&openSubtitlesHash=d55148e97384a3fb&plexHash=d13ecef156d64111af9fb90fc82414e407bb1da6&episode=404&season=1&show=Star%20Trek%20New%20Voyages%20Phase%20Ii<br />
Sep 08, 2010 03:45:44 [0xa0232720] WARN - No matches for search.<br />
Let me know if I missed something.
SC
Maybe this will work?
http://wiki.plexapp.com/index.php/Plex_Nine#Adding_Home_Movies
*Adding using the TV Show Scanner: Using this method will take all of your home movies and present them in three levels like TV Shows (TV Shows -> Season -> Episodes). To do this, follow the steps for adding a TV show section and change the Primary Info Provider to "Home Movies Series." Currently the interface for this method is incomplete and will resemble what is used for TV shows. The benefit of using this method is that you can organize your home movies better (Year -> Event -> Home movies). In order for this to work correctly, your home movie files must be named like date based TV episodes: /2009/New Years Eve/Happy New Year - 2009-12-31.mov.*
Thank you for the suggestion. I've actually tried that too and it does find the videos with the dashes in the names. However then I get a different problem which results in about half of my shows not being scanned.
If you have more than one video on the same date it will only find the first one. For example if you have:
2009-07-04 01 BBQ at the park.mov
2009-07-04 02 BBQ at the park.mov
2009-07-04 03 BBQ at the park.mov
It will only show the first video as episode "07-04" and the other two will be skipped.
So it depends on which half of my movies I want to show up. :)
It's not a huge issue for me... I can always add them the old way through the video plugins, but I'm trying to make sure the correct people are aware of the situation. It would be cool to have them off the home menu so that my family could find them easier.
I think actually it won't be skipped, but rather be "stacked" into one movie. If you simply rename so it doesn't look like stackable file that should work for now (e.g. 2009-07-04 BBQ at the park - Intro.mov
Thanks for that. So I went and tried it. It didn't quite work as expected.
I have two files from Jan 9.
2010-01-09 001.mp4
2010-01-09 002.mp4
In plex it shows "Episode 01-09" in the "Season 2010" which seems pretty cool. However if I play "Episode 01-09" what I would expect to happen based on your explanation is that both files would play back to back with the 001 file playing first. What actually happens is the 002 file plays and the 001 file does not play and is not in the library.
I also tried this...
I took the three files that were named
2010-02-27 001.mp4
2010-02-27 002.mp4
2010-02-27 003.mp4
and renamed them
2010-02-27 Ashley and her birthday cake.mp4
2010-02-27 Ashley opening presents.mp4
2010-02-27 Ashley playing musical chairs.mp4
I re-scanned the library... and now I do see an episode "Episode 02-27" and it's the file "2010-02-27 Ashley playing musical chairs.mp4". It's a little strange because all the episodes are listed numerically correct but this episode is the last episode in the season.
thanks for looking at this issue.
Oh, crap, I'm sorry, I think I screwed up the explanation. If you do date-based, the dates for all the files need to be different, otherwise they are merged (or should be) via stacking.
If you do episode based, you should be able to do: S01E01, S010E02, etc., same as regular TV shows. I'm currently working on a fix for the scanner so that you'll be able to name them S2010E01, etc. (with the year as season).
However, in your case you have multiple "episodes" for a single date, so I'll have to think about this a bit more, it doesn't fit neatly in with Show > Season > Episode, unless I'm missing something.
Found an issue with the movie “Extraordinary Measures”.
It doesn’t show up in the Media Manager, no traces of it in the log.
Directory structure is as follows:
/Volumes/Movies/2010/Extraordinary Measures/Extraordinary Measures.avi
Renaming the folder to “_Extraordinary Measures” or “Extr_aordinary Measures”
and, voila, it shows up. Renaming it to “Extra_ordinary Measures”, it will not.
Seems like it fails when the directory begins with the word “Extra”…
Well what I ended up doing and it's working fine is naming them like this.
S2010E001 20100704.avi
S2010E002 20100704.avi
S2010E003 20100704.avi
I wanted to keep the date in the filename because I've had issues in the past when moving files around between different file systems, new computers, ... where I've somehow managed to lose the created date metadata and I want to know the date the video was created. So now I make it a rule to always keep the date in the filename itself.
The only issue with doing this is that every time I import a new video from my camera I have to go in and modify the filename which I didn't have to do in the past.
I know everyone uses Plex differently and everyone has their priorities. For me home movies are important. My kids love watching the videos of themselves. Looking forward to what you come up with in the future. thanks.
