My Music/TV Shows/Movies Aren't Showing Up
Thanks, that worked a treat! :D
My media library is officially complete!
I don’t have the time to read through this thread right now, but no music was showing up in Plex under “Music” for me and I found the solution to my problem:
By accident I found that inside my music folder I had a symlink pointing to a non-existing location. I removed it and suddenly PMS was spinning like crazy scanning my music.
Got the same issue, only this ep (s03e06) is missing for some reason, all others scanned perfectly and show up in Plex.
Please post the full directory and filename so that I can reproduce over here (and sorry for the trouble!)
Elan,
Scanner has started skipping movies with numbers in the title, 300, 2012, 101 dalmatians. If I remove 101 from dalmatians it scans and gets added. In the logs, when it has a number in front, it does not even try to scan it.
/Volumes/Media/Movies/300 (2006).mp4
/Volumes/Media/Movies/2012.mkv
/Volumes/Media/Movies/102 Dalmatians.m4v
There's something odd going on here, because movies like that scan fine for me:
I don't see it even looking at those files:
<br />
Sep 14, 2010 07:40:17 [0xa07c8500] DEBUG - Looking for path match for [/Volumes/Media/Movies/10 Items or Less.mp4]<br />
Sep 14, 2010 07:40:17 [0xa07c8500] DEBUG - Looking for path match for [/Volumes/Media/Movies/10 Things I Hate About You.mkv]<br />
Sep 14, 2010 07:40:17 [0xa07c8500] DEBUG - Looking for path match for [/Volumes/Media/Movies/10,00 BC (2008).mkv]<br />
Sep 14, 2010 07:40:17 [0xa07c8500] DEBUG - Looking for path match for [/Volumes/Media/Movies/21.mkv]<br />
Sep 14, 2010 07:40:17 [0xa07c8500] DEBUG - Looking for path match for [/Volumes/Media/Movies/24 Hour Party People.mp4]<br />
Sep 14, 2010 07:40:17 [0xa07c8500] DEBUG - Looking for path match for [/Volumes/Media/Movies/27 Dresses.m4v]<br />
Sep 14, 2010 07:40:17 [0xa07c8500] DEBUG - Looking for path match for [/Volumes/Media/Movies/28 Weeks Later.mp4]<br />
Sep 14, 2010 07:40:17 [0xa07c8500] DEBUG - Looking for path match for [/Volumes/Media/Movies/3 Pigs and a Baby Unstable Fables.m4v]<br />
Sep 14, 2010 07:40:17 [0xa07c8500] DEBUG - Looking for path match for [/Volumes/Media/Movies/30 Days of Nights.mp4]<br />
It appears as if they're not even there?
Are you possibly running a custom/tweaked scanner?
"300", and other movies with numbers in the title, scans fine for me too.
I have a weird one, this:
/Volumes/Media/Stand Up/Edinburgh Comedy Festival Live/Edinburgh Comedy Festival Live S01E01.mkv
/Volumes/Media/Stand Up/Edinburgh Comedy Festival Live/Edinburgh Comedy Festival Live S01E02.mkv
Which is a custom section in PMS and uses the Movies/Plex Movie Scanner under the settings as most of my stand up is considered movies. However this does not scan, it won’t even show up with a thumbnail. If however I move to:
/Volumes/Media/TV/Edinburgh Comedy Festival Live/Edinburgh Comedy Festival Live S01E01.mkv
/Volumes/Media/TV/Edinburgh Comedy Festival Live/Edinburgh Comedy Festival Live S01E02.mkv
It will instantly scan and also get artwork. If I edit the section to be TV, it loses everything but the Edinburgh Comedy Festival stuff. When I look in the logs I can only see it listed with the thetvdb scanner.
Elan,
It is my edited Series scanner that breaks the movies. I took out my code to get shows that are named 303 to get scanned.
Shouldn’t the movies not pay attention to a tv series scanner?
I've been having the same issue. Here is the directory structure and filename:
/Volumes/Drobo/TV/Chuck/Chuck - Season 3/Chuck - S03E06 - Chuck vs. the Nacho Sampler.avi
Hey Elan.. Just to let you know that if you correctly title it chuck.s03e06.avi then add to library it will work. If you title it like this, it doesn't work. If you title it like this and then try to rename it, it won't work.
I'm gonna guess that "sample" in the title is causing this to not be added.
The movies scanner uses the TV scanner to ignore things that look like TV shows :-)
Of course, if you're in custom scanner-land you can have it do whatever you'd like!
Now that I bought my house, I will take a look at the email you sent me a couple of weeks ago for using my custom scanner. Glad I know what is going on at least. Thanks.
Not sure if you saw my post about G.J. Resolute? I can get it to scan but i cant find a match for it. If I try to manually fix it and search for G.I. Joe, all the other cartoons come up but this one. It worked when .9 was first released.
Thanks.
I have four missing movies in my library. When I started to scan there was only one missing. While it was scanning the number increased.
Tell me how I can find out which file is missing and I will tell you.
I can imagine that it scans some movies wrong, assumes a TV-show and removes it. But this would be fatal.
Btw:
In one scan there was Idiocracy (2006).mkv missing - I removed the section and scanned again and it was back.
I can’t get the movie “Summer in Genova” to show up in Plex. Have tried renaming, removing, rescanning, etc. etc. but no luck.
<br />
Sep 15, 2010 06:39:18 [0xa0153500] DEBUG -       * Scanning Summer in Genova<br />
Sep 15, 2010 06:39:18 [0xa0153500] DEBUG - Looking for path match for [/Volumes/Midlands/MEDIA/Videos/Movies/Summer in Genova.avi]<br />
Sep 15, 2010 06:39:18 [0xa0153500] DEBUG - We found a hash match for [/Volumes/Midlands/MEDIA/Videos/Movies/Summer in Genova.avi] which was [/Volumes/The_Crashdown/Movies/Dead Like Me - Life After Death.avi].<br />
Sep 15, 2010 06:39:18 [0xa0153500] DEBUG - Hint name didn't match ('Summer in Genova' != 'Dead Like Me Life After Death') for DB media item 1492<br />
Any help would be appreciated, thank you!
Try renaming your file to include the "full imdb" title:
Summer in Genoa (2008).avi
Whoops, slight typo there on my part. I've changed the title so many times I got them confused. But yes, I tried it as "Summer in Genoa.avi," "Summer in Genoa (2008).avi," "Genova.avi," "Genova (2008).avi," and even the (unintentional) slight bastardization "Summer in Genova (2008).avi." Heck, I even renamed it "The Lion King.avi" just to see if it would show up in the media manager at all, but no dice.
I double checked to make sure it's not showing up under another name, but my movie count according to Plex is 424, and according to Finder it's 425.
We're adding the ability to search by ID too, so that should be a nice stop-gap measure as we improve the agents' search functionality.
It looks like the hashes for those two movies is identical. Can you confirm that they are different? In order to share the same match, they would need the same exact file size and same exact 64KB start and end to the file, which seems unlikely.
No trouble at all, just a simple ls-copy-past combo :) Here you go:
<br />
[/share/MD0_DATA/TV Shows/01.TV-Series/Chuck/Season 3] # ls<br />
:2eDS_Store<br />
Chuck.S03E01.Chuck.vs.the.Pink.Slip.mkv<br />
Chuck.S03E01.Chuck.vs.the.Pink.Slip.nfo<br />
Chuck.S03E02.Chuck.vs.the.Three.Words.mkv<br />
Chuck.S03E02.Chuck.vs.the.Three.Words.nfo<br />
Chuck.S03E03.Chuck.vs.the.Angel.de.la.Muerte.mkv<br />
Chuck.S03E03.Chuck.vs.the.Angel.de.la.Muerte.nfo<br />
Chuck.S03E04.Chuck.vs.Operation.Awesome.mkv<br />
Chuck.S03E04.Chuck.vs.Operation.Awesome.nfo<br />
Chuck.S03E05.Chuck.vs.First.Class.mkv<br />
Chuck.S03E05.Chuck.vs.First.Class.nfo<br />
Chuck.S03E06.Chuck.vs.The.Nacho.Sampler.mkv<br />
Chuck.S03E06.Chuck.vs.The.Nacho.Sampler.nfo<br />
Chuck.S03E07.Chuck.vs.The.Mask.mkv<br />
Chuck.S03E07.Chuck.vs.The.Mask.nfo<br />
Chuck.S03E08.Chuck.vs.the.Fake.Name.mkv<br />
Chuck.S03E08.Chuck.vs.the.Fake.Name.nfo<br />
Chuck.S03E09.Chuck.vs.the.Beard.mkv<br />
Chuck.S03E09.Chuck.vs.the.Beard.nfo<br />
Chuck.S03E10.Chuck.vs.the.Tic.Tac.mkv<br />
Chuck.S03E10.Chuck.vs.the.Tic.Tac.nfo<br />
Chuck.S03E11.Chuck.vs.the.Final.Exam.mkv<br />
Chuck.S03E11.Chuck.vs.the.Final.Exam.nfo<br />
Chuck.S03E12.Chuck.vs.The.American.Hero.mkv<br />
Chuck.S03E12.Chuck.vs.The.American.Hero.nfo<br />
Chuck.S03E13.Chuck.vs.The.Other.Guy.mkv<br />
Chuck.S03E13.Chuck.vs.The.Other.Guy.nfo<br />
Chuck.S03E14.Chuck.vs.The.Honeymooners.mkv<br />
Chuck.S03E14.Chuck.vs.The.Honeymooners.nfo<br />
Chuck.S03E15.Chuck.Versus.the.Role.Models.mkv<br />
Chuck.S03E15.Chuck.Versus.the.Role.Models.nfo<br />
Chuck.S03E16.Chuck.Versus.the.Tooth.mkv<br />
Chuck.S03E16.Chuck.Versus.the.Tooth.nfo<br />
Chuck.S03E17.Chuck.Versus.the.Living.Dead.mkv<br />
Chuck.S03E17.Chuck.Versus.the.Living.Dead.nfo<br />
Chuck.S03E18.Chuck.Versus.the.Subway.mkv<br />
Chuck.S03E18.Chuck.Versus.the.Subway.nfo<br />
Chuck.S03E19.Chuck.Versus.the.Ring-.Part.2.mkv<br />
Chuck.S03E19.Chuck.Versus.the.Ring-.Part.2.nfo<br />
Let me know if you need anything else.
