myPlex token for local authentication ...
i have a question regarding the tokens.
i have a local server in my network. i enabled the local authentication. my app (dreamplex) is getting a token for the server no problem.
but ...
the user i connect with is a user that should have limited access. e.g. only sections for childs.
when the user connects i see that the normal token is used ...
We found auth token (xxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Aug 24, 2014 00:33:06 [0xf1cc3b70] DEBUG - Refreshing tokens inside the token-based authentication filter.
Aug 24, 2014 00:33:06 [0xf1cc3b70] DEBUG - HTTP requesting to: https://plex.tv/servers/xxxxxxxxxxxxxxxxxxx/access_tokens.xml?auth_token=xxxxxxxxxxxxxxxxxxxxxx
Aug 24, 2014 00:33:08 [0xf1cc3b70] DEBUG - MyPlex: Adding yyyyyyyyyyyyyyyyyyas token for 2 sections for DonDavici
Aug 24, 2014 00:33:08 [0xf1cc3b70] DEBUG - MyPlex: Added 5 super-tokens.
Aug 24, 2014 00:33:08 [0xf1cc3b70] VERBOSE - Comparing request from 192.168.xx.80 against 127.0.0.1/255.255.255.255
Aug 24, 2014 00:33:08 [0xf1cc3b70] VERBOSE - Completed request: GET /library/sections: 401
as far as i can see the token xxxxxx is used to generate another one -> yyyyyyyyyyyyy when i manually use the yyyyyyyyyy token from log file everything is working as expected.
now the question is. how can i find out the yyyyyyyyy token not going into the log files.
i am the developer of dreamplex and would need this information to implement into my third pary plugin.
any hint would help. thx in advance
