Server Version#: 4.12.3
Player Version#: Web player on Windows
So my question here.
I just started using hardware acceleration today, and I know that not EVERYTHING gets offloaded to GPU however there are instances where I’m seeing nothing offload.
My setup is as follows:
Dell R620 w/ Quadro p400 passed through to a Server 2016 VM in VMWare 6.5.
whatever is the most recent Quadro drivers for server 2016 are what is installed, I use GPU-Z to monitor GPU clock & GPU load, and when watching content I’ll go from the idle 139mhz to 1227.5mhz & see GPU load bounce between 5 and 15% if I’m “Converting” a 4k video.
I’ll also see about 30% CPU usage on the plex transcoder (4 cores allocated to the VM on an e5-2640)
I guess I’m just curious as to what all tweaks I may need to make or if there are conditions that I’m not meeting for whatever content i’m transcoding to be eligible to be transcoded on my GPU or something.
I’ve found a little bit of information here and there but nothing that is definitive regarding explaining why I’m seeing the behavior I am. the whole goal of doing this was reduce CPU load & be able to stream 2-3 high quality videos at the same time even if they happen to need to transcode or something.
Based on what I see in the logs it does look like it’s offloading. Unless i’m interpreting incorrectly.
an 25, 2020 23:09:07.974 [1984] Debug — Cleaning directory for session 5w8f4t6pnpfcafeps9njqo5p ()
Jan 25, 2020 23:09:07.974 [1984] Debug — Starting a transcode session 5w8f4t6pnpfcafeps9njqo5p at offset -1.0 (state=3)
Jan 25, 2020 23:09:07.974 [1984] Debug — TPU: hardware transcoding: using hardware decode accelerator nvdec
Jan 25, 2020 23:09:07.974 [1984] Debug — [Universal] Using local file path instead of URL: D:\Data\Video\Movies\Marvels Avengers - Infinity War\Avengers Infinity War 2018 REMUX 2160p (10bit) BluRay UHD HDR HEVC TrueHD DTS-HD MA 7 1-LEGi0N\Avengers.Infinity.War.2018.REMUX.2160p.(10bit).BluRay.UHD.HDR.HEVC.TrueHD.DTS-HD.MA.7.1-LEGi0N.mkv
Jan 25, 2020 23:09:07.974 [1984] Debug — TPU: hardware transcoding: zero-copy support not present
Jan 25, 2020 23:09:07.974 [1984] Debug — TPU: hardware transcoding: final decoder: nvdec, final encoder: nvenc
Jan 25, 2020 23:09:07.974 [1984] Debug — Job running: EAE_ROOT='\\?\C:\Users\Administrator\AppData\Local\Plex Media Server\Cache\Transcode\Sessions\EasyAudioEncoder' FFMPEG_EXTERNAL_LIBS='\\\\?\\C\:\\Users\\Administrator\\AppData\\Local\\Plex\ Media\ Server\\Codecs\\8bf330d-2818-windows-x86\\' X_PLEX_TOKEN='xxxxxxxxxxxxxxxxxxxx' C:\Program Files (x86)\Plex\Plex Media Server\Plex Transcoder.exe -codec:0 hevc -hwaccel:0 nvdec -hwaccel_fallback_threshold:0 10 -codec:1 dca -analyzeduration 20000000 -probesize 20000000 -i "D:\Data\Video\Movies\Marvels Avengers - Infinity War\Avengers Infinity War 2018 REMUX 2160p (10bit) BluRay UHD HDR HEVC TrueHD DTS-HD MA 7 1-LEGi0N\Avengers.Infinity.War.2018.REMUX.2160p.(10bit).BluRay.UHD.HDR.HEVC.TrueHD.DTS-HD.MA.7.1-LEGi0N.mkv" -filter_complex [0:0]scale=w=2276:h=1280[0];[0]format=pix_fmts=yuv420p|nv12[1] -filter_complex "[0:1] aresample=async=1:ocl='stereo':osr=48000[2]" -map [1] -metadata:s:0 language=eng -codec:0 h264_nvenc -b:0 54418k -maxrate:0 72558k -bufsize:0 145116k -preset:0 hp -forced-idr:0 1 -r:0 23.975999999999999 -force_key_frames:0 expr:gte(t,0+n_forced*1) -map [2] -metadata:s:1 language=eng -codec:1 aac_mf -b:1 256k -f dash -seg_duration 1 -init_seg_name init-stream$RepresentationID$.m4s -media_seg_name chunk-stream$RepresentationID$-$Number%05d$.m4s -window_size 5 -delete_removed false -skip_to_segment 1 -time_delta 0.0625 -manifest_name http://127.0.0.1:32400/video/:/transcode/session/5w8f4t6pnpfcafeps9njqo5p/bc3a8d80-fed6-4913-85ea-5209fffb8d70/manifest -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 dash -start_at_zero -copyts -vsync cfr -y -init_hw_device cuda=cuda: -hwaccel_device cuda -filter_hw_device cuda -nostats
Any positive input would be appreciated. Thanks in advance!
