Let’s say the the GPU can comfortably support x streams. When hardware acceleration for transcoding is enabled, does it start to use CPU for a few streams after x streams are already running on GPU? Or if hardware acceleration is enabled, no transcoding is ever done on CPU?
I would like it to use CPU if GPU resources are exhausted but I am having a hard time testing it.
I would like to know this too. TeknoJunky… does Linux run plex differently… or in other words… if linux allows the CPU to be used after the GPU is maxed… does that mean it does the same thing on a windows system?
I have a decent CPU and a crappy GPU. I want to make sure that when hardware acceleration is enabled that it doesn’t use just my GPU.
