I have written the plugin code. what is remaining are the site configs…
I am looking to do some basic site configs, nothing fancy like seekbar etc to start with but having some issues with them. Hope someone can help here.
I am trying to write site configs for:
Dailymotion
ZShare
With dailymotion I am unable to find the exact swf, I was able to listen to the audio but there is no video and plex still keep showing ‘opening page’…
I found another website which has dailymotion videos embedded http://ac.aapkatv.info/daily.php?code=xhut8y . With this one I was able to see the video screen on the display in plex but the video is paused by default. How do I start playing it? I even tried setting initialState=paused but that didnt help. I have attached site config for this one.
I am also having issue with ZShare, again the video is paused there and we need to click on the close button of the ad and close button shows after like 5 seconds. How can we achieve that? eg. video url: http://www.zshare.net/video/883496050fc47bd4/
any help is appriciated… will post my plugin as soon as i am able to solve this issue…
The regex with the * at the end will only match zero or more /-characters. If ac.aapkatv.info is the website you’re writing a plugin for, and this site embeds videos from Daily Motion, the site tag of your site config should look something like this:
<site site="http://ac.aapkatv.info"<br />
plugin="http://.*dailymotion.com/swf"<br />
initialState="paused"<br />
version="1.0"<br />
randomAgent="true"><br />
I was able to workaround the dailymotion by having my own mirror where I enabled autoplay since I was able to display the correct thing anyway… only issue was clicking the play button which is paused by default…
i have similar issue with zshare. I attached the xml i use. the issue is that on the site, we need to click on the close button before the video will start. how can i achieve that? i tried clicking after a few seconds etc but nothing seems to help… the swf is in a iframe and i also give the direct url to the iframe but still no luck…
can someone help with with zshare… i will post my plugin as soon as i am able to get zshare working…
thanks.
