Siteconfig Issue
Getting sound but no image
I've been trying to get this site config for dailymotion.com to work properly and don't seem to be having any luck. My issue is that I get sound, but the video doesn't come up (just continue seeing the "opening stream" thing indefinitely). It's still a bit incomplete in that I haven't been able to test the progress bar or anything due to the fact that the video doesn't come up, but that's kind of secondary to just getting the basics to work.
I have put together a couple siteconfig files in the past and not had a lot of issues, so I'm kinda stumped as to what the problem may be in this case. Any pointers would be greatly appreciated, or if someone wants to just send me a fixed version of the file I obviously wont object either :D
Hey Riviera, the plug-in URLs look like this:
http://www.dailymotion.com/flash/dmplayer/dmplayer.swf?1198004557
I changed the plug-in regex to look like this:
plugin="http://www.dailymotion.com/flash/dmplayer/dmplayer.swf.*"
And it worked great.
Looking forward to the plug-in!
Damnit, I even tried it with the statically defined number, but didn’t occur to me that I could use a wildcard there. Thanks a lot for looking at it. Definitely saved me a lot of time :slight_smile:
Not actually writing a plugin for dailymotion itself but just the videos for la blogotheque that are hosted on there. Am hoping someone else may use the siteconfig and write a plugin for dailymotion itself. May end up doing it myself if that doesn’t happen and I find some time though.
