"Next" button in "Get Info" dialog
I think it would be useful to be able to walk through the Media Info for a playlist or album without leaving the ‘Get Info’ dialog:
Whether you’re in the context of a playlist, collection, or album detail (anyplace where there’s a list of items), the Get Info > Next button should walk through the list.
This is a ‘Nice to have’ feature.
I take it you’re expanding on this suggestion which is asking for the same feature for the regular Edit modal?
I hadn’t seen that. Yes, I’m suggesting a similar feature. I would not have considered the ‘Edit’ and ‘Get Info’ modals to be so similar as to be covered by the same suggestion.
I don’t think they are the same… just wanted to make sure I understood you’re aiming for the same behavior :wink:
Adding navigation buttons to move between media items while in the ‘Media Info’ view in Plex would save lots of opening and closing of this dialogue. I have provided a suggestion in the image above.
