Thanks for the tip about Packet size. I’ve upped it to 32k.
Re-performing my test shows even worse speed, maybe because I’m doing a bunch of transcode operations in the background utilizing NFS heavily as well as watching something from Plex on my desktop.
Wizard Earth:umount /downloads
Wizard Earth:mount -o rsize=131072,wsize=131072,async jupiter:/volume1/downloads /downloads
Wizard Earth:dd if=/downloads/America\'s\ Got\ Talent\ S17E03\ -\ Auditions\ 3.mkv of=/dev/null bs=4M status=progress
3149668176 bytes (3.1 GB, 2.9 GiB) copied, 541 s, 5.8 MB/s
750+1 records in
750+1 records out
3149668176 bytes (3.1 GB, 2.9 GiB) copied, 540.715 s, 5.8 MB/s
Wizard Earth:
Still, the Resource Monitor on the Synology in the Overview section never shows anything for NFS 'cept 0%.
Even though there is NFS activity:
OK, I quiesced the network activity and redid the dd:
566231040 bytes (566 MB, 540 MiB) copied, 8 s, 68.9 MB/s
750+1 records in
750+1 records out
3149668176 bytes (3.1 GB, 2.9 GiB) copied, 8.91319 s, 353 MB/s
Wizard Earth:
Much better.
As for FastEthernet (networking and hardware are my weak spots) I know I have the GigaBlaster package from Cox and get about 900Mbit down when wired and about 300Mbit when wireless (my desktop is wireless). I have a switch coming from the GigaBlaster router so that I can wire my Synology Plex server, my TV, and my PS4. I’m assuming I can get Gigabit speeds on the LAN if everything was wired.
I have a Synology 1019+ with 4 10Tb drives on /volume1. My 5th bay has a throwaway 500G drive that I don’t really use on /volume2.
