No access after installation
Server Version#: 1.41.3.9314-72009314
I just installed Plex server on synology, latest version OS and server app. New installation, have set the share preferences to allow the Plex user access to my shares.
Click on ‘Open’, Plex opens in new Tab, login with my Gmail account and immediatly after i get this message that i don’t have access.
" Niet toegestaan
U hebt geen toegang tot deze server.
U kunt het mogelijk claimen door “Open Plex…” te kiezen in het Plex-menu in de macOS-menubalk of het Windows-systeemvak. Voor meer probleemoplossingstips, zie ons [ondersteuningsartikel]."
The page that links to, wants me to delete some credentials in the Preference.xml file, but that text isn’t even in the xml. So absolutely no use for me.
Why isn’t this working for me?
Can you get terminal access to your synology device? If so try GitHub - ChuckPa/UserCredentialReset: User Credential Reset utility for Plex
I now de-installed the software, re-installed it and used a claim code at installation, and now it works.
