No channels for my users
Hello. I have been using Plex for years. The channels section has never interested me until now.
So I decide to add to my Plex. Everything is fine it’s simple and it works. I added the cannal tou.tv.
Problem: I have different user . But none shows the channels. Only the user (master) has the channels.
I searched all the menus of the users and invited no one by I find how to activate the channels for my users.
Thank you for your help.
There is a checkbox under the permissions for the user that allows channels when logged into the server as the admin.
The location of said checkbox:
Settings > Users > edit icon for user > Restrictions
EDIT: The downside, is that they will get access to all of your channels. I have certain ones in there that are more tools than channels. I’m not sure I would want someone playing with those.
Thanks to you two !!
