I am trying to record the Cricket on Channel 4 in the UK tomorrow, how do I do this if it does not appear on the Underpowered by Plex EPG, no cricket for me
we feel your pain.
You might like to know that @markcs has a script right now that pulls 24 hours of EPG from the HDHomeRun itself. You can get it here . Note it’s the hr_epg.pl script you want to use. The others are Freeview Australia. It’s great in a pinch and may help you out tomorrow. …you will need to delete your DVR and re-install it to read the generated file though.
Thanks will give that a try, wish that Plex would just use an EPG provider that worked when it was changed at short notice, they might want to look at Gracenote going forward
and I have asked for this before, as well as lot of other forum users, why can we not just pick a channel on our DVR and manually set a start and stop time to record it?
is that humour? …sorry not sure because Gracenote is what they have just moved away from.
Yes it was, worked a lot better with Gracenote
You might like to start here.
…sorry, this EPG ■■■■-up is exhausting.
I’ve never been redacted before; I only wrote a variation on cook-up…
Probably going to give this a miss, though Plex employees should look at the whole thread and test a replacement EPG before inflicting it on users.
no worries.
Best suggestion i have heard
Gracenote has the cricket shown for tomorrow
Just doing a Full Refresh of the EPG Underpowered by Plex to see if the Cricket appears and that I can record it tomorrow, not holding out much hope
Completed the scan, no Cricket for me from Plex, I have no way of recording the UK Channel 4 and UK More 4 Cricket, as it does not appear in your useless EPG
…for what it’s worth, Channel 4 is ridiculously wrong anyway. I can see it, but it thinks tomorrow is The Simpsons and “Sunday Brunch” when the cricket is on.
More 4 is no better which is wrong all day…
no cricket for me
did you manage to watch it? …I’m not saying anything until you reply…
Managed to watch it, but not to record it via Plex, as most of the morning was missing from the Channel 4 EPG.
shame. It was EPIC.
