No Hardware Transcoding on Plex
Server Version: 1.25.6.5577
Hello,
I just switched from DSM to OMV, and I have a problem, Plex refuses to hard transcode my media.
No problem with Jellyfin
With you an idea? ( chmod 777 /dev/dri or specifying GUID=107 does not change anything
Merci
My compose :
  plex:
    image: lscr.io/linuxserver/plex:amd64-latest
    container_name: EVOPlex
    network_mode: host
    environment:
      - PUID=1001
      - PGID=100
      - VERSION=latest
      - UMASK=022
    mem_limit: 8192M
    devices:
      - /dev/dri:/dev/dri
    volumes:
      - ./plex/transcode:/transcode
      - ./plex/config:/config
    restart: unless-stopped
Please ask in the OMV forums.
Sorry , but OMV isn’t officially supported
To make matters worse, I have been unable to install OMV in a VM for testing / vetting.
You might want to look at this
Relative addressing? wouldn’t you use an absolute path?
Hello,
Thank you for your reply.
I’ve done this before with no solution.
Either way, no change :frowning:
​Hello !
I found the solution.
On Synology ( DSM ), I needed to add VaapiDriver=“i965” in Preferences.xml at some point for hard transcoding to work. I just deleted it now that I’m on OMV, and hard transcoding works! Thank you​
This is on a -10xxx CPU?
Yes , i3-10100T
thanks. The i965 driver can only be used up through the -9xxx CPUs.
The -10xxx is a clean break on Intel’s part from all things in the past; including the i965
Thank you for that clarification :slight_smile:
