Good day
It seems i have no more access to actor’s biography when i select one from the cast.
Why is that?
Same issue on IOS app
Thanks and best regards
Good day
Why is that?
Is the library in question setup using the Plex Movie / Plex TV Series agents?
Affirmative, using Plex Movie scanner.
I made no change on this and i used to have access to the biography for actors which is no longer the case
Thanks in advance and best regards
I’ve just tested this on my own setup and it seems to be working fine for me.
Do you by chance have enabled the Include adult content option in the advanced library configuration?
Hello
Thanks for your reply.
“include adult content” is not activated.
My PMS Version 1.32.7.7571
Plex Web Version 4.116.1
IOS version 8.26
Do you have same version of PMS?
Hello
Problem solved!
I think my filters on ADGUARD were too agressive…
Thanks for sharing!
