No servers found
Hello, even though this question is found x times when searching the Internet I can´t find any solution.
I´m running Libreelec Kodi 18.9 Leia with Kodi Plugin 0.2.3 on a Rpi4 and everything used to work as expected.
At one point (and I know I didn´t change anything) all other clients work fine except the plex plugin for kodi. The PMS is outside my local network, and I can access it with the Plex Desktop app and the webinterface. All hosts are on the same network and are using exact the same DNS server and the same router.
When enabling debugging I can see:
NOTICE: script.plex: API: DEBUG: Connection: https://192-168-178-20.xxx.plex.direct:32400 local: True token: ****Qd7u sources: MYPLEX state: unknown
and:
NOTICE: script.plex: API: DEBUG: Reachability result for ‘PLEX-NAS’: https://192-168-178-20.xxxplex.direct:32400 is unreachable
When signing off and sign in again this works like charm… but still the PlexMediaServer can not be reached.
Any help is appreciated…
L
