I have a problem with the thumbnails on my system. They appear on the android and web app, but not on rasplex (without without caching).
This is the same issue as mine:
If someone as an idea why it`s doing that, I would appreciate!
Thank you
Thank you
Possible SD card corruption, have you tried reflashing?
Regards
Check the permissions on the folders that contain your libraries, should be owned by plex:plex. They need to be able to be read by user plex.
Regards
What OS is your PMS server running?
Regards
As said on github, PMS running under freebsd (actually nas4free but its not really important). I check on my laptop with plex home theater and I have the same problem.
Maybe we should move the topic to the PMS section… and a dev might help…
