thumbnails not loading, not in cache
hello,
i recently had to re-install rasplex and am now having difficulty with thumbnails (film jackets and back art, but also the "dolby digital" logo). approximately one-third of thumbnails do not appear, and a few of those that do are distorted as if file was loaded partially.
i have checked the images on the server. and they load correctly when i access from my iphone. i also checked a second rasplex box and the thumbnails are all present in cache.
i re-installed a few days ago and can see that the cache is not growing in size. as the faq suggests, i have scrolled through the all movies section several times over the last few days. but to no avail...
has anyone had similar experiences, or have any ideas ?  thanks !
- scott
Please post your logfiles to be able to identify the issue. Some other users reported reinstalling will fix this issue too.
hello again,
here is my log file. i have already tried a reinstall with identical results. thanks !
- scott
01:00:11 T:3047744016  NOTICE: -----------------------------------------------------------------------
01:00:12 T:3047744016  NOTICE: Starting Plex Home Theater (0.9.9.7-20130712-352a5ac7), Platform: Linux (rasplex - Version: 0.2.2, 3.6.11 armv6l). Built on Jul 12 2013
01:00:12 T:3047744016  NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
01:00:12 T:3047744016  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/plexhometheater
01:00:12 T:3047744016  NOTICE: special://masterprofile/ is mapped to: /storage/.plexht/userdata
01:00:12 T:3047744016  NOTICE: special://home/ is mapped to: /storage/.plexht
01:00:12 T:3047744016  NOTICE: special://temp/ is mapped to: /storage/.plexht/temp
01:00:12 T:3047744016  NOTICE: The executable running is: /usr/lib/plexhometheater/plexhometheater
01:00:12 T:3047744016  NOTICE: Local hostname: RasLiving
01:00:12 T:3047744016  NOTICE: Log File is located: /storage/.plexht/temp/xbmc.log
01:00:12 T:3047744016  NOTICE: -----------------------------------------------------------------------
01:00:12 T:3047744016  NOTICE: load settings...
22:35:58 T:3047744016  NOTICE: special://profile/ is mapped to: special://masterprofile/
22:35:58 T:3047744016  NOTICE: loading special://masterprofile/guisettings.xml
22:35:58 T:3047744016  NOTICE: Getting hardware information now...
22:35:58 T:3047744016  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
22:35:58 T:3047744016  NOTICE: Loaded playercorefactory configuration
22:35:58 T:3047744016  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
22:35:58 T:3047744016  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
22:35:58 T:3047744016  NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
22:35:58 T:3047744016  NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
                                              77
                                              /opt/vc/bin/vcgencmd measure_temp | sed -e 's/temp=\([0-9]*\).*/\1 C/'
                                                30242880
                                              560
                                              256
                                                omxplayer
                                                omxplayer
                                                paplayer
                                                false
                                                3
                                                0
                                              2
                                              false
                                              false
22:35:58 T:3047744016  NOTICE: Loaded settings file from special://profile/advancedsettings.xml
22:35:58 T:3047744016  NOTICE: Contents of special://profile/advancedsettings.xml are...
                                              77
                                                30242880
                                              560
                                              256
                                                omxplayer
                                                omxplayer
                                                paplayer
                                                false
                                                3
                                                0
                                              2
                                              false
                                              false
22:35:58 T:3047744016  NOTICE: Default DVD Player: omxplayer
22:35:58 T:3047744016  NOTICE: Default Video Player: omxplayer
22:35:58 T:3047744016  NOTICE: Default Audio Player: paplayer
22:35:58 T:3047744016  NOTICE: Disabled debug logging due to GUI setting. Level 0.
22:35:58 T:3047744016  NOTICE: Log level changed to 0
22:35:58 T:3047744016  NOTICE: Loading media sources from special://masterprofile/sources.xml
22:35:59 T:3047744016   ERROR: Error: Requested setting (audiooutput.guisoundmode) was not found.  It must be case-sensitive
22:35:59 T:3047744016  NOTICE: Running database version Addons15
22:35:59 T:3037721696  NOTICE: Thread AutoUpdateThread start, auto delete: false
22:35:59 T:2985292896  NOTICE: Thread PlexSourceScanner: 192.168.0.15 start, auto delete: true
22:35:59 T:2985292896  NOTICE: Plex Source Scanner starting...(192.168.0.15) (uuid: 5e6eaf5d88b9824becb14d5e40c2e893729ffd1f)
22:36:00 T:3004167264  NOTICE: PlexDirectory::GetDirectory(https://my.plexapp.com/pms/servers.xml?X-Plex-Token=SECRETSTUFF)
22:36:00 T:2985292896  NOTICE: Scanning remote server: 192.168.0.15 (remote: 0)
22:36:00 T:2985292896  NOTICE: PlexDirectory::GetDirectory(http://192.168.0.15:32400/music)
22:36:00 T:2985292896  NOTICE: PlexDirectory::GetDirectory(http://192.168.0.15:32400/video)
22:36:00 T:2985292896  NOTICE: PlexDirectory::GetDirectory(http://192.168.0.15:32400/photos)
22:36:00 T:2985292896  NOTICE: PlexDirectory::GetDirectory(http://192.168.0.15:32400/applications)
22:36:00 T:2985292896  NOTICE: PlexDirectory::GetDirectory(http://192.168.0.15:32400/library/sections)
22:36:01 T:2985292896  NOTICE:  -> Local section 'Kids' found.
22:36:01 T:2985292896  NOTICE:  -> Local section 'Kids TV' found.
22:36:01 T:2985292896  NOTICE:  -> Local section 'Movies' found.
22:36:01 T:2985292896  NOTICE:  -> Local section 'Music' found.
22:36:01 T:2985292896  NOTICE:  -> Local section 'TV Shows' found.
22:36:01 T:2985292896  NOTICE:  -> Local section 'Videos' found.
22:36:01 T:2985292896  NOTICE: Scanning host 192.168.0.15 is complete.
22:36:01 T:2985292896  NOTICE: Plex Source Scanner finished for host 192.168.0.15[Tirion] (0 left)
22:36:01 T:3047744016  NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
22:36:01 T:2966529120  NOTICE: Thread XBMC Peripherals start, auto delete: false
22:36:01 T:2975794272  NOTICE: Thread CEC Adapter start, auto delete: false
22:36:01 T:2958140512  NOTICE: Thread XBMC Peripherals start, auto delete: false
22:36:01 T:3047744016  NOTICE: Raspberry PI firmware version: Jun  6 2013 18:30:04
                                            Copyright (c) 2012 Broadcom
                                            version e6f0abde03216306997292�sh
22:36:01 T:3047744016  NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi
22:36:01 T:3047744016  NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 60.000000 Hz
22:36:01 T:3047744016  NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 60.000000 Hz
22:36:01 T:3047744016  NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
22:36:01 T:3047744016  NOTICE: Found resolution 1280 x 360 for display 0 with 1280 x 360 @ 60.000000 Hz
22:36:01 T:3047744016  NOTICE: Found resolution 1280 x 720 for display 0 with 1920 x 1080 @ 60.000000 Hz
22:36:01 T:3047744016  NOTICE: Found resolution 640 x 720 for display 0 with 960 x 1080i @ 60.000000 Hz
22:36:01 T:3047744016  NOTICE: Found resolution 720 x 576 for display 0 with 720 x 576 @ 50.000000 Hz
22:36:01 T:3047744016  NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
22:36:01 T:3047744016  NOTICE: Found resolution 1280 x 360 for display 0 with 1280 x 360 @ 50.000000 Hz
22:36:01 T:3047744016  NOTICE: Found resolution 1280 x 720 for display 0 with 1920 x 1080 @ 50.000000 Hz
22:36:01 T:3047744016  NOTICE: Found resolution 640 x 720 for display 0 with 960 x 1080i @ 50.000000 Hz
22:36:01 T:3047744016  NOTICE: Found resolution 1280 x 720 for display 0 with 1920 x 1080 @ 24.000000 Hz
22:36:01 T:3047744016  NOTICE: Found resolution 1280 x 360 for display 0 with 1920 x 540 @ 24.000000 Hz
22:36:01 T:3047744016  NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 60.000000 Hz
22:36:01 T:3047744016  NOTICE: Found resolution 848 x 480 for display 0 with 848 x 480 @ 60.000000 Hz
22:36:01 T:3047744016  NOTICE: Found resolution 960 x 720 for display 0 with 1024 x 768 @ 60.000000 Hz
22:36:01 T:3047744016  NOTICE: Found (1280x720@60.000000) at 20, setting to RES_DESKTOP at 16
22:36:01 T:3047744016  NOTICE: Checking resolution 16
22:36:01 T:3047744016  NOTICE: GL_VENDOR = Broadcom
22:36:01 T:3047744016  NOTICE: GL_RENDERER = VideoCore IV HW
22:36:01 T:3047744016  NOTICE: GL_VERSION = OpenGL ES 2.0
22:36:01 T:3047744016  NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
22:36:01 T:3047744016  NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
22:36:02 T:3004167264  NOTICE: PlexDirectory::GetDirectory(https://my.plexapp.com/pms/playlists/queue?X-Plex-Token=SECRETSTUFF)
22:36:04 T:3004167264  NOTICE: PlexDirectory::GetDirectory(https://my.plexapp.com/pms/playlists/recommendations?X-Plex-Token=SECRETSTUFF)
22:36:04 T:2975794272   ERROR: CecLogMessage - failed to release the previous LA
22:36:04 T:2975794272   ERROR: CecLogMessage - could not open a connection (try 1)
22:36:06 T:3047744016  NOTICE: Running database version Addons15
22:36:06 T:3047744016  NOTICE: Running database version ViewModes4
22:36:06 T:3047744016  NOTICE: Running database version Textures13
22:36:06 T:3047744016  NOTICE: Running database version MyMusic32
22:36:06 T:3047744016  NOTICE: Running database version MyVideos75
22:36:06 T:3047744016  NOTICE: Running database version TV22
22:36:06 T:3047744016  NOTICE: Running database version Epg7
22:36:06 T:3047744016  NOTICE: initializing playlistplayer
22:36:06 T:3047744016  NOTICE: DONE initializing playlistplayer
22:36:06 T:3004167264  NOTICE: Thread CEC Adapter Update Thread start, auto delete: false
22:36:07 T:3047744016   ERROR: Couldn't load font name: LargeSearchFont(Arial), trying to substitute arial.ttf
22:36:07 T:3047744016   ERROR: Couldn't load font name: MediumSearchFont(Arial), trying to substitute arial.ttf
22:36:07 T:3047744016   ERROR: Couldn't load font name: SearchResult(Arial), trying to substitute arial.ttf
22:36:07 T:3047744016   ERROR: Couldn't load font name: SearchResultSmaller(Arial), trying to substitute arial.ttf
22:36:07 T:3047744016   ERROR: Couldn't load font name: SearchResultSmall(Arial), trying to substitute arial.ttf
22:36:07 T:3047744016   ERROR: Couldn't load font name: LargeTitleFont(Arial), trying to substitute arial.ttf
22:36:07 T:3047744016   ERROR: Couldn't load font name: MediaPreviewYear(Arial), trying to substitute arial.ttf
22:36:07 T:3047744016   ERROR: Couldn't load font name: MediaPreviewSummary(Arial), trying to substitute arial.ttf
22:36:07 T:3047744016   ERROR: Couldn't load font name: MediaPreviewDetailsHeader(Arial), trying to substitute arial.ttf
22:36:07 T:3047744016   ERROR: Couldn't load font name: EpisodeTitles(Arial), trying to substitute arial.ttf
22:36:07 T:3047744016   ERROR: Couldn't load font name: NPArtistFont(Arial), trying to substitute arial.ttf
22:36:07 T:3047744016   ERROR: Couldn't load font name: NPTitleFont(Arial), trying to substitute arial.ttf
22:36:07 T:3047744016   ERROR: Couldn't load font name: NPAlbumFont(Arial), trying to substitute arial.ttf
22:36:07 T:3047744016   ERROR: Couldn't load font name: NPNextFont(Arial), trying to substitute arial.ttf
22:36:08 T:3047744016   ERROR: Couldn't load font name: XLargeDefaultFont(Arial), trying to substitute arial.ttf
22:36:08 T:3047744016   ERROR: Couldn't load font name: XLargeDefaultCapsFont(Arial), trying to substitute arial.ttf
22:36:08 T:3047744016   ERROR: Couldn't load font name: LargeDefaultFont(Arial), trying to substitute arial.ttf
22:36:08 T:3047744016   ERROR: Couldn't load font name: LargeDefaultCapsFont(Arial), trying to substitute arial.ttf
22:36:08 T:3047744016   ERROR: Couldn't load font name: MediumDefaultFont(Arial), trying to substitute arial.ttf
22:36:08 T:3047744016   ERROR: Couldn't load font name: MediumAltDefaultFont(Arial), trying to substitute arial.ttf
22:36:08 T:3047744016   ERROR: Couldn't load font name: MediumDefaultCapsFont(Arial), trying to substitute arial.ttf
22:36:08 T:3047744016   ERROR: Couldn't load font name: MediumSmallDefaultFont(Arial), trying to substitute arial.ttf
22:36:08 T:3047744016   ERROR: Couldn't load font name: MediumSmallAltDefaultFont(Arial), trying to substitute arial.ttf
22:36:08 T:3047744016   ERROR: Couldn't load font name: MediumSmallDefaultCapsFont(Arial), trying to substitute arial.ttf
22:36:08 T:3047744016   ERROR: Couldn't load font name: DefaultFont(Arial), trying to substitute arial.ttf
22:36:08 T:3047744016   ERROR: Couldn't load font name: AltDefaultFont(Arial), trying to substitute arial.ttf
22:36:08 T:3047744016   ERROR: Couldn't load font name: DefaultCapsFont(Arial), trying to substitute arial.ttf
22:36:08 T:3047744016   ERROR: Couldn't load font name: SmallDefaultFont(Arial), trying to substitute arial.ttf
22:36:08 T:3047744016   ERROR: Couldn't load font name: SmallDefaultCapsFont(Arial), trying to substitute arial.ttf
22:36:08 T:3047744016   ERROR: Couldn't load font name: SmallerDefaultFont(Arial), trying to substitute arial.ttf
22:36:08 T:3047744016   ERROR: Couldn't load font name: SmallerDefaultCapsFont(Arial), trying to substitute arial.ttf
22:36:08 T:3047744016   ERROR: Couldn't load font name: XXXLargeTitleCapsFont(Arial), trying to substitute arial.ttf
22:36:08 T:3047744016   ERROR: Couldn't load font name: XXXXLargeTitleCapsFont(Arial), trying to substitute arial.ttf
22:36:08 T:3047744016   ERROR: Couldn't load font name: XLargeTitleFont(Arial), trying to substitute arial.ttf
22:36:08 T:3047744016   ERROR: Couldn't load font name: XLargeTitleCapsFont(Arial), trying to substitute arial.ttf
22:36:08 T:3047744016   ERROR: Couldn't load font name: LargeTitleCapsFont(Arial), trying to substitute arial.ttf
22:36:08 T:3047744016   ERROR: Couldn't load font name: MediumLargeTitleFont(Arial), trying to substitute arial.ttf
22:36:08 T:3047744016   ERROR: Couldn't load font name: HomeScreenUnselectedItems(Arial), trying to substitute arial.ttf
22:36:08 T:3047744016   ERROR: Couldn't load font name: MediumLargeTitleCapsFont(Arial), trying to substitute arial.ttf
22:36:08 T:3047744016   ERROR: Couldn't load font name: TitleFont(Arial), trying to substitute arial.ttf
22:36:08 T:3047744016   ERROR: Couldn't load font name: TitleCapsFont(Arial), trying to substitute arial.ttf
22:36:08 T:3047744016   ERROR: Couldn't load font name: MediumTitleFont(Arial), trying to substitute arial.ttf
22:36:08 T:3047744016   ERROR: Couldn't load font name: MediumTitleCapsFont(Arial), trying to substitute arial.ttf
22:36:09 T:3047744016   ERROR: Couldn't load font name: RssFeedFont(Arial), trying to substitute arial.ttf
22:36:09 T:3047744016   ERROR: Couldn't load font name: MediumSmallTitleFont(Arial), trying to substitute arial.ttf
22:36:09 T:3047744016   ERROR: Couldn't load font name: MediumSmallTitleFont2(Arial), trying to substitute arial.ttf
22:36:09 T:3047744016   ERROR: Couldn't load font name: MediumSmallTitleFont3(Arial), trying to substitute arial.ttf
22:36:09 T:3047744016   ERROR: Couldn't load font name: MediumSmallTitleCapsFont(Arial), trying to substitute arial.ttf
22:36:09 T:3047744016   ERROR: Couldn't load font name: SmallTitleFont(Arial), trying to substitute arial.ttf
22:36:09 T:3047744016   ERROR: Couldn't load font name: SmallTitleCapsFont(Arial), trying to substitute arial.ttf
22:36:09 T:3047744016   ERROR: Couldn't load font name: SmallTinyTitleFont(Arial), trying to substitute arial.ttf
22:36:09 T:3047744016   ERROR: Couldn't load font name: SmallTinyTitleCapsFont(Arial), trying to substitute arial.ttf
22:36:09 T:3047744016   ERROR: Couldn't load font name: TinyTitleFont(Arial), trying to substitute arial.ttf
22:36:09 T:3047744016   ERROR: Couldn't load font name: TinyTitleCapsFont(Arial), trying to substitute arial.ttf
22:36:09 T:3047744016   ERROR: Couldn't load font name: HomeMenuFocusFont(Arial), trying to substitute arial.ttf
22:36:09 T:3047744016   ERROR: Couldn't load font name: HomeMenuInfoFont(Arial), trying to substitute arial.ttf
22:36:09 T:3047744016   ERROR: Couldn't load font name: HomeSubMenuFont(Arial), trying to substitute arial.ttf
22:36:09 T:3047744016   ERROR: Couldn't load font name: VideoDetailXFont(Arial), trying to substitute arial.ttf
22:36:09 T:3047744016   ERROR: Couldn't load font name: VideoDetailXCapsFont(Arial), trying to substitute arial.ttf
22:36:09 T:3047744016   ERROR: Couldn't load font name: KeyboardFocusFont(Arial), trying to substitute arial.ttf
22:36:09 T:3047744016   ERROR: Couldn't load font name: KeyboardFocusCapsFont(Arial), trying to substitute arial.ttf
22:36:09 T:3047744016   ERROR: Couldn't load font name: font13(Arial), trying to substitute arial.ttf
22:36:12 T:3047744016   ERROR: unable to load:/usr/share/xbmc/addons/skin.mediastream/720p/DialogExtendedProgressBar.xml, Line 0
                                            Failed to open file
22:36:13 T:3047744016   ERROR: unable to load:/usr/share/xbmc/addons/skin.mediastream/720p/DialogFilters.xml, Line 0
                                            Failed to open file
22:36:13 T:3047744016 WARNING: CreateFile, successfuly opened  instead of
22:36:14 T:3047744016  NOTICE: initialize done
22:36:14 T:3047744016  NOTICE: Running the application...
22:36:14 T:2896815200  NOTICE: Thread XBPyThread start, auto delete: false
22:36:14 T:2896815200  NOTICE: -->Python Interpreter Initialized<--
22:36:17 T:2879845472  NOTICE: Thread Jobworker start, auto delete: true
22:36:17 T:2879845472  NOTICE: PlexDirectory::GetDirectory(http://192.168.0.15:32400/library/sections/3/recentlyAdded?unwatched=1&X-Plex-Container-Size=10&X-Plex-Container-Start=0)
22:36:17 T:2871456864  NOTICE: Thread Jobworker start, auto delete: true
22:36:17 T:2871456864  NOTICE: PlexDirectory::GetDirectory(http://192.168.0.15:32400/library/sections/3/onDeck)
22:36:17 T:2863068256  NOTICE: Thread Jobworker start, auto delete: true
22:36:17 T:2863068256  NOTICE: PlexDirectory::GetDirectory(http://192.168.0.15:32400/library/sections/5/recentlyAdded?unwatched=1&X-Plex-Container-Size=10&X-Plex-Container-Start=0)
22:36:17 T:2854679648  NOTICE: Thread Jobworker start, auto delete: true
22:36:17 T:2854679648  NOTICE: PlexDirectory::GetDirectory(http://192.168.0.15:32400/library/sections/5/onDeck)
22:36:17 T:2854679648  NOTICE: PlexDirectory::GetDirectory(http://192.168.0.15:32400/library/sections/8/recentlyAdded?unwatched=1&X-Plex-Container-Size=10&X-Plex-Container-Start=0)
22:36:17 T:2846291040  NOTICE: Thread Jobworker start, auto delete: true
22:36:17 T:2846291040  NOTICE: PlexDirectory::GetDirectory(http://192.168.0.15:32400/library/sections/8/onDeck)
22:36:17 T:2837902432  NOTICE: Thread Jobworker start, auto delete: true
22:36:17 T:2837902432  NOTICE: PlexDirectory::GetDirectory(http://192.168.0.15:32400/library/sections/9/recentlyAdded?unwatched=1&X-Plex-Container-Size=10&X-Plex-Container-Start=0)
22:36:17 T:2829513824  NOTICE: Thread Jobworker start, auto delete: true
22:36:17 T:2829513824  NOTICE: PlexDirectory::GetDirectory(http://192.168.0.15:32400/library/sections/2/recentlyAdded?unwatched=1&X-Plex-Container-Size=10&X-Plex-Container-Start=0)
22:36:17 T:2821125216  NOTICE: Thread Jobworker start, auto delete: true
22:36:17 T:2821125216  NOTICE: PlexDirectory::GetDirectory(http://192.168.0.15:32400/library/sections/2/onDeck)
22:36:17 T:2812736608  NOTICE: Thread Jobworker start, auto delete: true
22:36:17 T:2812736608  NOTICE: PlexDirectory::GetDirectory(http://192.168.0.15:32400/library/sections/6/recentlyAdded?unwatched=1&X-Plex-Container-Size=10&X-Plex-Container-Start=0)
22:36:17 T:2802840672  NOTICE: Thread Jobworker start, auto delete: true
22:36:17 T:2802840672  NOTICE: PlexDirectory::GetDirectory(http://192.168.0.15:32400/library/sections/6/onDeck)
22:36:18 T:2794452064  NOTICE: Thread Background Runner start, auto delete: true
22:36:19 T:2735141984  NOTICE: Previous line repeats 2 times.
22:36:19 T:2735141984  NOTICE: Thread CFileCache start, auto delete: false
22:36:19 T:2735141984  NOTICE: Thread Background Runner start, auto delete: true
22:36:30 T:2802840672  NOTICE: Previous line repeats 1 times.
22:36:30 T:2802840672  NOTICE: PlexDirectory::GetDirectory(https://my.plexapp.com/pms/playlists//queue/unwatched?X-Plex-Token=SECRETSTUFF)
22:36:30 T:2772948064  NOTICE: Thread Background Runner start, auto delete: true
22:36:30 T:2837902432  NOTICE: Previous line repeats 4 times.
22:36:30 T:2837902432   ERROR: COMXImage::ReadFile special://masterprofile/Thumbnails/1/1dd62ffb.jpg not found
22:36:30 T:2837902432   ERROR: Texture manager unable to load file: special://masterprofile/Thumbnails/1/1dd62ffb.jpg
22:36:31 T:2846291040   ERROR: COMXImage::ReadFile special://masterprofile/Thumbnails/1/1490348a.jpg not found
22:36:31 T:2846291040   ERROR: Texture manager unable to load file: special://masterprofile/Thumbnails/1/1490348a.jpg
22:36:31 T:2863068256   ERROR: COMXImage::ReadFile special://masterprofile/Thumbnails/1/13261e5c.jpg not found
22:36:31 T:2863068256   ERROR: Texture manager unable to load file: special://masterprofile/Thumbnails/1/13261e5c.jpg
22:36:33 T:2837902432   ERROR: COMXImage::ReadFile special://masterprofile/Thumbnails/1/17bbfa4a.jpg not found
22:36:33 T:2837902432   ERROR: Texture manager unable to load file: special://masterprofile/Thumbnails/1/17bbfa4a.jpg
22:36:33 T:2879845472  NOTICE: PlexDirectory::GetDirectory(https://my.plexapp.com/pms/playlists//recommendations/unwatched?X-Plex-Token=SECRETSTUFF)
22:36:33 T:2854679648  NOTICE: PlexDirectory::GetDirectory(http://192.168.0.15:32400/channels/recentlyViewed?filter=video)
22:36:33 T:2821125216  NOTICE: PlexDirectory::GetDirectory(http://192.168.0.15:32400/channels/arts)
22:36:33 T:2854679648  NOTICE: PlexDirectory::GetDirectory(http://192.168.0.15:32400/channels/recentlyViewed?filter=music)
22:36:34 T:2726007904  NOTICE: Thread CFileCache start, auto delete: false
22:36:37 T:2896815200  NOTICE: Previous line repeats 5 times.
22:36:37 T:2896815200  NOTICE: ## OpenELEC Addon ## 0.1.23
22:36:37 T:3047744016  NOTICE: Webserver: Starting...
22:36:37 T:3047744016  NOTICE: WebServer: Started the webserver
22:36:37 T:3047744016  NOTICE: ES: Starting event server
22:36:37 T:3047744016  NOTICE: starting zeroconf publishing
22:36:37 T:2651956320  NOTICE: Thread CTCPServer start, auto delete: false
22:36:37 T:2660344928  NOTICE: Thread CEventServer start, auto delete: false
22:36:37 T:2660344928  NOTICE: ES: Starting UDP Event server on 0.0.0.0:9778
22:36:37 T:2660344928  NOTICE: UDP: Listening on port 9778
22:36:37 T:2643567712  NOTICE: Thread AirPlayServer start, auto delete: false
22:36:37 T:2635179104  NOTICE: Thread AirTunesServer start, auto delete: false
22:36:37 T:2896815200  NOTICE: None
22:40:33 T:2993681504  NOTICE: Previous line repeats 81 times.
22:40:33 T:2993681504 WARNING: FillBuffer: curl failed with code 28
22:40:33 T:2993681504   ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
I seem to be having the same issue, let me know if you would like to see my log file as well.  You will have to tell me where to get the log file from, but then I would know for next time.
/storage/.plexht/temp/plexhometheater.log
This issue might by memory-related too… Do you have a 256Mb RPi?
Please login via ssh and take a look at your memory usage (via top, etc.)
hello again,
to answer the question, i have a 512 mp rpi. top shows :
Mem: 286616K used, 22252K free, 0K shrd, 30452K buff, 125820K cached
out of desperation i re-installed last night. i carefully scrolled through the movie section, and each loaded. the same for tv shows, albeit much more slowly. when i did the same for my daughter's move section rasplex froze.
after reboot, 10% of previously loaded thumbnails are now absent. very frustrating as this *was* working fine before my initial problem...
here is the latest log file. thanks again for any and all help !
- scott
plexhometheater.log (25.5 KB)
hi,
out of curiosity i downloaded all the thumbnails to look at them. i found a bunch of files that had errors. this probably explaining why the image doesn't display in plex. here is an example :
edit : the forum uploader refuses most of these files, maybe because of the errors.
if i look on my other rasplex, the same file looks like this :
![post-33064-0-58354400-1380352038.jpg|690x388](upload://e27V06JmC4a4U4kPK6e25ecpmlA.jpg)
i also found a corrupted image file that shows no error :
![post-33064-0-24614300-1380351585.jpg|690x388](upload://pxU2hcanBjiR3yxbAwEvMgvIQG2.jpg)
any ideas on what could be happening to these files ?  merci !
- scott
and ...
i deleted the bad thumbnails off the rpi. rasplex doesn't seem to 'regenerate' them. even after a boot. is there some way to do this ?
- scott
scott451, on 28 Sept 2013 - 12:48, said:
and ...
- scott
It should be possible to delete userdata/Thumbnails - but this is generally not a good idea. -- DON'T DO THIS -- if you don't want to get into trouble.
yes,
it is possible. and as i said it doesn't change anything...
but what to do then ?  it seems that files are being corrupted on my card as they are stored. is it the card, rasplex, openelec, ... ?
help !
- scott
Sorry - the easiest way would be probably to just reinstall RasPlex. But this seems to not fix your problem … How large is your library?
hi,
library is large, over 650 1080p films, plus sd tv series, and a bunch of music. thumbnail directory is now around 200 mo.
latest re-install of 0.2.2 seems to have fixed the problem for now, though i did notice a corrupted album cover yesterday ...
i will see what happens with new version of plex once i can get it installed.
any hypothesis on what the problem could be, hardware, software, ...   ?
thanks
- scott
