Over the past few months I have noticed that a lot of my content will not transcode. I think it may have to do with the files not being compatible with plex. It plays fine when local and direct play. I am on plex version 1.11.2.4772. Here is an example of a file that that will not transcode.
General
Unique ID : 195108437011502323731527344493976226106 (0x92C884A3CB5E4EF6B4B3838BC222093A)
Complete name : \unraid\Media\Plex\TV Shows\S9FYLJ~3\Season 01\S01E15 - xxxxxxxx.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 1.07 GiB
Duration : 45 min 12 s
Overall bit rate mode : Variable
Overall bit rate : 3 393 kb/s
Encoded date : UTC 2018-02-12 01:04:24
Writing application : mkvmerge v13.0.0 (‘The Juggler’) 64bit
Writing library : libebml v1.3.4 + libmatroska v1.4.5
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L3.1
Format settings : CABAC / 5 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate mode : Variable
Bit rate : 2 751 kb/s
Maximum bit rate : 4 500 kb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.124
Stream size : 889 MiB (81%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : E-AC-3
Format/Info : Enhanced Audio Coding 3
Codec ID : A_EAC3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 187.500 FPS (256 SPF)
Compression mode : Lossy
Stream size : 207 MiB (19%)
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 43 min 54 s
Bit rate : 62 b/s
Count of elements : 711
Stream size : 20.1 KiB (0%)
Language : English
Default : No
Forced : No
Text #2
Format : UTF-8
Duration : 43 min 58 s
Bit rate : 64 b/s
Count of elements : 751
Stream size : 20.8 KiB (0%)
Title : SDH
Language : English
Default : No
Forced : No
