Gloppie
November 28, 2022, 11:57am
1
Server Version#: latest as of today
Player Version#: doesnt matter
Plex Commercial[31984]: segfault at 0 ip 00007f732643c7df sp 00007ffc69db4b80 error 4 in Plex Commercial Skip
per[7f7326411000+2f000]
[498915.965489] Code: f3 0f 10 15 7f 23 fd ff 83 7d c8 00 74 3d 85 db 7e 74 31 d2 31 c0 48 8b b4 d5 10 ff ff ff 48 8d 7e 04 4
8 89 bc d5 10 ff ff ff 0f 10 06 f3 0f 59 c2 0f 57 c9 f3 0f 2a c8 f3 0f 58 c8 f3 0f 2c
Maybe this:
master ← rcombs:separate-codec
Hello,
this is the only build compiling on my arm64 device with latest debian d… ocker image. But when running it crashes with a segmentation fault. After some testing I found the place responsible for this crash:
mpeg2dec.c, Line 571:
`for (l=0;l < is->audio_st->codecpar->channels;l++ ) volume += *((fb[l])++) * 64000;`
When commenting this line out (or when always evaluating the if statement in Line 570 to false), the program is running fine and even finding commercials without a problem.
Is this an issue caused by your changes or a different problem? Any ideas what could be the reason for it?
sa2000
November 28, 2022, 1:48pm
2
There is a later build than the one you are running on EPYC: 1.30.0.6406-F3F2FCC0
Plex Media Server 1.30.0.6442 is now available to Plex Pass users in the Beta update channel.
NEW:
(PlexMatch) Add support for pattern matching (#13899)
(Scheduled Tasks) Perform periodic metadata refreshes on TV shows too (#13920)
(Transcoder) Support zero-copy hardware transcoding on macOS (#13904)
FIXES:
(Artwork) Restrict client artwork screensaver to items user is allowed to access (#13916)
(DVR) Plex Tuner Service might become unresponsive in certain complex scenarios (#12988)
(Music…
1.30.0.6442
Is it the same with this version?
Do you have the original recording file ?
Could you get the debug server logs when the commercial skipper runs
Also log text files within the media directories it uses
I’ve been unable to reproduce this, but I think it’s a direct result of plex not cleaning up the /tmp dir of .jpg’s resulting in a full tmpdir causing the error.
sa2000
December 9, 2022, 10:36am
4
We do leave the purge of /tmp and %TEMP% on windows to the OS
