Nvidia RTX 3090 (24GB GDDR6)
I am about to purchase a new computer sporting the following:
Componet Purpose
AMD Ryzen B550 ATX Platform
Gigabyte B550 Vision D-P Motherboard
AMD Ryzen 9 5950X 3.4GHz Sixteen Core 105W CPU
4 x DDR4-3200 32GB Ram
NVIDIA GeForce RTX 3090 24GB Open Air Video Card
With this configuration, I would like to be able to transcode “4k, 2160p, 50Mbps” down to “Mobile, 720p, 4Mbps” without Plex flinching – with 5-10 concurrent transcodes possible.
Is this a feasible goal with this configuration?
Thank you for your input.
I think consumer Nvidia cards are limited to 3 concurrent transcodes, and even if they weren’t, asking for a machine to transcode 10 4K 50Mbps probably HDR videos down to tone mapped 720p 4Mbps streams is going to cripple even the most powerful of machines. My question would be why do you need that kind of horsepower and why would that scenario ever come up? A better solution would be to make mobile optimized versions of those videos to avoid absolutely crushing your machine all the time for transcoding. I will add though that I like the hardware choice with the exception of the B550 board. If you are going to go with that level of hardware and want to use it in a “server” environment where PCIe lanes are going to be important, I would move up to X570 or onto the Threadripper platform.
I really don’t know – I haven’t purchased the computer yet – as I’m still solidifying things like this. With that said, my entire 15TB library is entirely 1080p because I always get the error that my CPU or Network wasn’t fast enough or something to that effect – right now I have a server without a GPU.
My current transcode limit is 5, and that’s really not been an issue – I think I was just being greedy – I just really want to get some 4K content.
I suppose I could “Optimize” a video for mobile (never had to do that, as I only have relatively low quality 1080p) … will Plex automatically decide on a version, based on the line capabilities? Like if I try to watch on my mobile in a poor/low bandwidth area, will Plex only play the mobile optimized version?
Thanks for the feedback!
Based on your feedback, how about this configuration instead?
Componet Purpose
AMD Threadripper TRX40 ATX Platform
Asus Strix TRX40-XE Motherboard
AMD Ryzen Threadripper 3960X 3.8GHz 24 Core 280W CPU
8 x DDR4-3200 32GB Ram
Onboard Sound Sound Card
Integrated WiFi+Bluetooth Networking
Samsung 980 Pro 1TB Gen4 M.2 SSD Hard Drive (Primary Drive)
Samsung 980 Pro 2TB Gen4 M.2 SSD Hard Drive (Secondary Drive)
Samsung 980 Pro 2TB Gen4 M.2 SSD Hard Drive (Tertiary Drive)
Asus 16x Blu-ray Burner SATA (black) CD / DVD Rom
Fractal Design Define 7 Case
Super Flower LEADEX Platinum 1200W Power Supply
Noctua NH-U14S TR4-SP3 CPU Cooling
Case Fans Upgrade Kit (PWM Ramping) Additional Cooling
Windows 10 Pro 64-bit Operating System
Seeking absolute peak Plex performance when working with 4k, 2160p, 50Mbps HDR content, and about 10 remote users.
PLEX does a pretty good job at auto selecting content based on client and network capabilities. So if you have 4K, 1080p, and 720p versions of a film, PLEX in most instances does a pretty great job of selecting the correct file based on the parameters that it needs to meet. So maintaining a library that contains 4K and 1080p or 720p versions of your films is a pretty good method to alleviate server strain from having to transcode massive bitrate files. As for the system specs, I think that looks like a monster system. The reason I suggested the changes earlier was I foresee you keeping this system for a long time and just adding storage as it becomes necessary. This would necessitate a substantial number of PCIe lanes to keep expanding into the future. The raw horsepower of either system is going to be plenty with the exception of the GPU. As I said earlier I believe that consumer cards like the 3090 are limited to 3 concurrent transcodes even if the GPU is capable of a whole lot more. I would look at something like an RTX 4000 or similar. That prevents you from having to do any driver modification to get more then 3 transcodes on the card.
Can you point me towards any documentation on the transcoding limits? I have no issue changing the card if I can find legit documentation about those restrictions.
Video Encode and Decode GPU Support Matrix [NEW] | NVIDIA Developer
Thank you a ton for all your help! I will change the card to the Nvidia RTX A5000 for sure!
No problem. Sounds like a monster machine for Plex. Hopefully you use it for more then just Plex lol. Have fun building it my friend!
