Ah, thank you for the clarification. Appreciate it.
Thanks so much for your reply, @sixones - I really appreciate it. It helps just knowing somebody at Plex is aware that this is an issue and that it is being actively addressed. If you have time, could you comment on what factors limit this issue primarily to the Android version of the Plex client? Is it an Exoplayer HLS implementation issue? (I can successfully direct-stream video with subtitles and transcoded audio on both Plex Media Player on the desktop, as well as Kodi with the Plex plugin on Android/AndroidTV.)
This needs to fixed⦠The Plex player is on ExoPlayer2 now⦠It can direct play SRT fine.
The only reason they had to burn them in was because they would go out of sync from a HLS bug that was fixed already in Exoplayer2.
Stop Transcoding Video / Burning Subtitles just because Audio is transcoding⦠Itās NOT Needed.
@sixones - you are awesome for responding. For me on Nvidia Shield, .srt subtitles do not work even when Iām using ac3, which my soundbar definitely supports. In fact, .srt subtitles donāt work at all unless I set it to āburn alwaysā. This isnāt a problem with any other client Iāve used⦠and I know lots of other people have complained that .srt subs simply will not work since the update. Iāve noticed that sometimes when I select my .srt, it will just show chapter xx instead of the subs. This isnāt a problem with Kodi with the Plex addon, nor is it a problem online.
Any chance Plex knows about this and is fixing it? Itās been like this for me for months. Again, thanks for your help!
This is a different issue than the one for this thread. See this thread for more people with the same problem youāre having:
Iāll check it out, thank you @rwoffice.
Is this also and issue with PGS subtitles, and not just SRT subtitles ?
PGS are picture based subtitles so they have to be burned in if the client canāt play them natively
Just curious, is this really a big technical obstacle? Emby android app has been transcoding subtitles to webvtt since forever and it just works with hls streaming. I mean itās really just text conversion, it doesnāt seem to be that difficult to implement.
This is a huge inconvenience to plex users on Android based clients including fire and android tv. The moment you turn on subtitles, server load is a lot more, everything loads slower, seeking becomes almost unusable.
This is the reason Iāve been using emby for local/lan streaming
Itās just an excuse for them⦠They are both text based subtitles and it can be converted on the fly in less then 5 seconds.
Here is an example of a line from an srt.
00:36:14,339 --> 00:36:18,051
We should have come here ages ago.
and here is an example of a line in WebVVT format.
00:36:14.339 --> 00:36:18.051
Apparently periods and commaās are too advanced to change in real time.
Iām sincerely hoping that with the latest update and focus on improving the subtitle experience (and the functionality of the Android player) that solving this issue will be among the priorities of the dev team. @sixones - fingers crossed that Iāll soon be able to make use of my Shield TV Plex client again.
This is a major issue that causes huge loads of stress on our servers, text based subtitles being such a big problem for Plex is really strange.
Same problem here. Everything direct plays on Roku but transcodes on PS4 when subtitiles are used.
Any news on this?
Is there any reason not to just convert SRT subtitles to WebVTT? Itās super easy to do, takes literally only like 1 second to convert, and it would solve this whole problem. Thereās even free websites where you can convert, so it canāt be that difficult. Hereās an example:
Yeah itās very strange that Plex doesnāt offer proper support to the most used subtitle format (srt) when the only thing needed to be done with the subtitles is to change commas to dots in the timestamps.
Yeah. Itās months and still no fix for this. Itās really driving me to click on reject payment on my paypal. I guess Iām really, really close.
@sixones, you talked 4 months ago about trying to remove limitations (HLS not supporting SRT & Plex not supporting WebVTT). Any update/decision on this?
Thanks.
@sixones any kind of update would be greatly appreciated, even one that says āitās on our roadmap but weāre not there yet.ā Please know that this is just as infuriating now as it was when I created this thread eight months ago about it, and is something that those of us on the Android client deal with on a daily basis. Thanks in advance.
Speaking for myself I just donāt use the Plex client anymore. As I am not a native English or Japanese speaker (I like Japanese anime) I need subtitles 100% of the time (ok, I understand English very well but Iāll always miss the occasional word or phrase, not to mention weird accents etc).
As a consequence anything that the Shield canāt direct play will cause a full transcode if I use the Plex client, something unacceptable. So I gave up on it and switched to Kodi as my playback client using PlexKodiConnect to connect those two.
Nevertheless, that solution is not for everyone especially if you have to deal with multiple servers, or just remote servers. Plex for Kodi was a good solution for those cases but it seems abandoned for months now.
In any case Iām not surprised with this dragging on, the direction of Plex as a company seems to be unstable lately with questionable decisions. Just look at the Roku client section and the public uproar that was causedā¦
