Odroid XU4?
Anyone had success in getting OpenPHT built and running on an XU4?
Not supported, only Odroid C2.
Regards
Any plans?
No, not at the moment, it’s good for running PMS though.
Regards
The XU4 with its USB3.0 makes it better as the PMS. I had hoped to run OpenPHT on same box.
Any plans to make this work? Its been an year since the last post here.
I have an XU4 gathering dust in a box. Although better on paper it has some inherent design flaw that means little ongoing software support. I got burner by Cubox i4pro same way. Gave up on flakey one off ARM devices & investigating Intel NUC devices instead. YMMV.
Any plans for support XU4?
