Offline Cloud
I have a Seagate Wireless Plus hard drive.  The hardware is great, all it is missing is Plex :)  On a long car or plane ride, or in a hotel with poor wifi, this 1 TB drive has tons of room for movies for the whole family.  It creates its own wifi hotspot that multiple devices can connect to and stream from, essentially making it an "Offline Cloud."
But there are a few problems:
* You have to manually run handbrake on your media and copy it over to the drive
* The web interface is basically just a file listing, not nearly as useful or intuitive as Plex
So the request is to add Plex to this device.  I'm envisioning that it would work like the Cloud Sync service, where you connect to your main server and choose which movies to sync and Plex automatically transcodes and copies the files.  Then when you are on the road you connect to the drive's hotspot and watch movies using your normal Plex clients. Ideally, when the drive is back on the network it would update the "watched" status for each user.
The tricky part is authenticating users without access to plex.tv.  Perhaps this means clients have to connect once when the internet is available and let it cache credentials somehow, or perhaps there is no authentication and it just plays content anonymously to anyone that is connected to the drive's hotspot (the hotspot is password protected, so that isn't as scary as it sounds).
I don't think this solution needs the ability to add content or manipulate the library directly.  It would be simplest to treat it like the cloud drive, where all management happens through your main Plex server.
I think this would be an excellent addition to the Plex family of products, giving you access to your library even when offline.
I would be a huge fan of this.
I travel frequently and don't always have time to sync when I'm at home and, with hotel WiFi being hit or miss, it's not always an option to stream or sync while on the go.
Right now I'm using a Seagate Wireless Plus with Infuse 2 on my iPad and it's working quite well, but I would love to be able to just use Plex in a sort of offline mode.
It would be great if we could set up the Wireless Plus as a sort of CloudSync device.
Of course, I don't have the wherewithal to know all the considerations that would be involved in such a request...but never hurts to ask.
plus 1  :rolleyes:
Maybe start by adding an option to sync files based on predefined device settings to a USB HDD as first step.
Yes, I very much like the idea of a "Port-a-Plex".  I travel with the family often.  Rather than deal with making sure each family member's device, usually with limited available storage, has synced before we head out, I'd much rather have content synced with a single high capacity device, like a Wireless Plus, or even a router with USB storage attached.
The idea was implemented!
https://www.plex.tv/blog/endless-summer-plex-western-digital/
Just not on my Seagate :~
