Older versions on older Mac
Server Version#:0.9.15.1663
Player Version#:??
Hello,
I try to run an older Version on an older Mac. Unfortunately There is no later version that runs on this OS. It is only to stream inside my LAN. I did not get any possibilities to configure it. Is there an option i have to select during the Installation?
Here are some pictures from the system
thank you for your help.
best Regards
Can you please offer your hardware model and year and MacOS you have installed.?
thanks for the fast reply,
Its a Mac mini2.1 2007 with mac OS 10.6.8 The program runs, but i don’t have the possibility to make something.
It looks like your out of luck.
Is it possible to use a linux distro like ubuntu on your mini to run Plex?
Unfortunately it not only a media server it is also a file and printer server so, no i can’t switch to linux.
