On Deck limited to 3
Just wondering if it would be possible to get the 3 dots underneath on deck to display more than 3 shows? Much like 'Recently Added Television' and 'Recently Added Movies' has on the first screen.
Thanks - loving the app so far!
for me when there are more than 3 objects there it does display the 3 dots.
This is a bug if you have exactly 2 or 4 or 6 items in your "on deck" list
1 Item => shows correctly with no [...]
2 items = shows only 1 => no [...]
3 items => shows correctly (no [...] needed)
4 items shows only 3 => no [...]
5 items => shows correctly (no [...] needed)
6 items shows only 5 => no [...]
beginning from 7 items it shows 5 items and the [...] are also correctly shown.
Thanks Mike - that explains it as I currently have 4.
I've noticed this exact same behaviour with the On Deck in the Xbox app. I'd never used the On Deck much until this app, but now that I use it this bug is kind of annoying because I'll finish an episode of a show, but then I'll want to watch a different one but an item was removed by watching the previous show and now the show I want doesn't show up (holy run on sentence, hope it sort of makes sense).
Just wanted to bump this up to make sure a dev will see it.
Yep, I’m having the same problem with On Deck. Shrunk to one when I had two shows On Deck, then it disappeared entirely.
