On Deck only 40 items
I also can not understand why it takes so long. Since the announcement that it should be changed several server versions have been released. But in any server version, I find in the change history an indication that it has been changed. So slow I’m almost so far that I give up hope. On the other hand, I strongly need this change because Plex (as good as it is otherwise) is not really workable for me. I watch every tv show only once a week, but a lot of tv shows.
Could not you at least give a clue how long we have to wait.
Move to the top
Move to the top so it will not be forgotten
I’m thinking it has been forgotten! I wouldn’t get your hopes up.
Probably wished he never said “given it’s such a simple change it’ll almost certainly be in the next release, but if not in the one after that.”
My workaround is going to TV Shows then sorting “By Date Viewed”. It seems to work whether you choose “All” or “Unplayed”. It comes up pretty fast too which (in my opinion) negates the argument that increasing On Deck will slow things down. This shows ALL your library so the ultimate workaround.
A server version with this change is currently in Alpha testing.
This are good news. Thanks
@Bernie07
Thanks for the update. It works perfect. I’ve set the new option to 60.
Best wishes
Bernhard
