Right now we have to press the middle button, press right two times and then press the middle button again. (At least on NVIDIA Shield).
It would be nice to just press the middle button once in order to skip an intro (like it is in the Netflix app), especially on a Device heavily marketed for PLEX Support (at least when I bought it)
I’m a bit surprised and tested this on my Sony Android TV.
When the intro approaches, I get an overlay button with the option to skip. I click OK (“middle button”) and Plex skips it. No navigating or clicking other buttons.
On what version of Plex for Android (TV) do you experience this?
Yeah, not as easy as it sounds. Button remapper only lets you do that (actually change codes) once you activated USB Debugging, which doesn’t work when your remote uses a BT dongle to connect.
Most 3rd party remotes actually have this issue, since they are technically keyboards with less buttons…
Sadly nothing you can really do but petition the author of the app to change it in order to accept the alternative input. (PLEX actually isn’t as bad as others, since ENTER at least opens the overlay)
