Server Version#: 1.25.3.5385
Player Version#: All
Tuner Make/Model: HD Homerun
Guide/Lineup name: Magenta TV
Using XMLTV?: No
Channel number/Name: VOX HD
Live TV works fine but there is one channel (VOX HD) which I can’t get to work no matter which EPG I try. The EPG is presented fine for this channel but trying to record this channel results in the following log errors:
Jan 14, 2022 08:42:04.435 [0x7fc4b9f13b38] Fehler — [Grabber/e29a8d3c37d00c9355cfc64c1d3b6a55f32981ea] Unable to find title for item of type 5
Jan 14, 2022 08:42:04.436 [0x7fc4b9f13b38] Fehler — [Grabber/e29a8d3c37d00c9355cfc64c1d3b6a55f32981ea] Unable to find title for item of type 5
Jan 14, 2022 08:42:06.439 [0x7fc4ba0b6b38] Fehler — [Transcoder] [NULL @ 0x7f0663e3ab40] non-existing PPS 0 referenced
Jan 14, 2022 08:42:06.440 [0x7fc4bdc80b38] Fehler — [Transcoder] [h264 @ 0x7f0663e3ab40] non-existing PPS 0 referenced
Jan 14, 2022 08:42:06.441 [0x7fc4ba7e3b38] Fehler — [Transcoder] [h264 @ 0x7f0663e3ab40] decode_slice_header error
Jan 14, 2022 08:42:06.441 [0x7fc4ba0b6b38] Fehler — [Transcoder] [h264 @ 0x7f0663e3ab40] no frame!
Jan 14, 2022 08:42:06.442 [0x7fc4bdc80b38] Fehler — [Transcoder] [h264 @ 0x7f0663e3ab40] non-existing PPS 0 referenced
Jan 14, 2022 08:42:06.443 [0x7fc4ba7e3b38] Fehler — [Transcoder] [h264 @ 0x7f0663e3ab40] non-existing PPS 0 referenced
Jan 14, 2022 08:42:06.443 [0x7fc4ba0b6b38] Fehler — [Transcoder] [h264 @ 0x7f0663e3ab40] decode_slice_header error
Jan 14, 2022 08:42:06.444 [0x7fc4bdc80b38] Fehler — [Transcoder] [h264 @ 0x7f0663e3ab40] no frame!
Jan 14, 2022 08:42:06.444 [0x7fc4ba7e3b38] Fehler — [Transcoder] [h264 @ 0x7f0663e3ab40] non-existing PPS 0 referenced
Jan 14, 2022 08:42:06.445 [0x7fc4ba0b6b38] Fehler — [Transcoder] [h264 @ 0x7f0663e3ab40] non-existing PPS 0 referenced
Jan 14, 2022 08:42:06.446 [0x7fc4bdc80b38] Fehler — [Transcoder] [h264 @ 0x7f0663e3ab40] decode_slice_header error
Jan 14, 2022 08:42:06.446 [0x7fc4ba7e3b38] Fehler — [Transcoder] [h264 @ 0x7f0663e3ab40] no frame!
Jan 14, 2022 08:42:06.447 [0x7fc4ba0b6b38] Fehler — [Transcoder] [h264 @ 0x7f0663e3ab40] non-existing PPS 0 referenced
Jan 14, 2022 08:42:06.448 [0x7fc4bdc80b38] Fehler — [Transcoder] [h264 @ 0x7f0663e3ab40] non-existing PPS 0 referenced
Jan 14, 2022 08:42:06.448 [0x7fc4ba7e3b38] Fehler — [Transcoder] [h264 @ 0x7f0663e3ab40] decode_slice_header error
Jan 14, 2022 08:42:06.448 [0x7fc4ba0b6b38] Fehler — [Transcoder] [h264 @ 0x7f0663e3ab40] no frame!
Jan 14, 2022 08:42:06.450 [0x7fc4bdc80b38] Fehler — [Transcoder] [h264 @ 0x7f0663e3ab40] non-existing PPS 0 referenced
Jan 14, 2022 08:42:06.451 [0x7fc4ba7e3b38] Fehler — [Transcoder] [h264 @ 0x7f0663e3ab40] non-existing PPS 0 referenced
Jan 14, 2022 08:42:06.451 [0x7fc4ba0b6b38] Fehler — [Transcoder] [h264 @ 0x7f0663e3ab40] decode_slice_header error
Jan 14, 2022 08:42:06.452 [0x7fc4bdc80b38] Fehler — [Transcoder] [h264 @ 0x7f0663e3ab40] no frame!
Jan 14, 2022 08:42:06.452 [0x7fc4ba7e3b38] Fehler — [Transcoder] [h264 @ 0x7f0663e3ab40] non-existing PPS 0 referenced
Jan 14, 2022 08:42:06.453 [0x7fc4ba0b6b38] Fehler — [Transcoder] [h264 @ 0x7f0663e3ab40] non-existing PPS 0 referenced
Jan 14, 2022 08:42:06.453 [0x7fc4bdc80b38] Fehler — [Transcoder] [h264 @ 0x7f0663e3ab40] decode_slice_header error
Jan 14, 2022 08:42:06.454 [0x7fc4ba7e3b38] Fehler — [Transcoder] [h264 @ 0x7f0663e3ab40] no frame!
Jan 14, 2022 08:42:06.839 [0x7fc4ba0b6b38] Fehler — [Transcoder] [h264 @ 0x7f0663e3ab40] non-existing PPS 0 referenced
Jan 14, 2022 08:42:06.840 [0x7fc4bdc80b38] Fehler — [Transcoder] [h264 @ 0x7f0663e3ab40] non-existing PPS 0 referenced
Jan 14, 2022 08:42:06.840 [0x7fc4ba7e3b38] Fehler — [Transcoder] [h264 @ 0x7f0663e3ab40] decode_slice_header error
Jan 14, 2022 08:42:06.841 [0x7fc4ba0b6b38] Fehler — [Transcoder] [h264 @ 0x7f0663e3ab40] no frame!
Jan 14, 2022 08:42:08.173 [0x7fc4b9f13b38] Fehler — [Grabber/e29a8d3c37d00c9355cfc64c1d3b6a55f32981ea] Unable to find title for item of type 5
Jan 14, 2022 08:42:08.174 [0x7fc4b9f13b38] Fehler — [Grabber/e29a8d3c37d00c9355cfc64c1d3b6a55f32981ea] Unable to find title for item of type 5
So it seems the title isn’t found but I have no idea why. Anyone has any idea where to look to fix this issue?
Just playing the channel does work btw.
Recording any other channel is working too.
