(ONLY FOR SERIOUS TESTERS) Bleeding Edge Testing Releases
Hello forum,
Being french please excuse my english (google is my friend lol).
I wanted to congratulate you on your work on PlexForKodi. I tested the version 0.14a2, for now at home I’m no problem, on the contrary, I’m telling that it was passed in French.
I wanted to know, if before releasing this new version, do you work on displaying collections for movies?
Collections (as well as other features that the other TV clients have that are not yet in the app) is on the list of things to be added. I don’t have any estimates on when those things will get in, but other than maybe a couple more fixes, there’s nothing more going to be added for the next release that isn’t in the current testing version.
Is it possible to add local plex server without use plex.tv account?
I cant see any options on plugin startup where i can set up ip of my pms.
I dont use plex.tv account on my local server and it isn’t claim.
Hi, inside the plugin (in the settings menu) you can set a PMS IP address manually. Hasn’t worked for me without logging in though, maybe it will for you.
Can’t go inside the plugin because on first run I need login to plex.tv, but I don’t want. I want just enter my server ip on plugin start
script.plex-0.1.5a1:
  • Allow direct playback of episodes and movies using the play button on hub screen (thanks to pannal)
  • In progress watched items had the ‘Mark unwatched’ option instead of ‘Mark watched’
  • Fix an issue causing the home window to start slightly scrolled down if it was closed scolled down
  • Fix an issue causing an error when sort was sort was “BY UNWATCHED” and the filtering “UNWATCHED” (Issue #187)
  • Fix issue with letter shortcuts sometimes being shown/not shown incorrectly
Instructions for adding the testing repo in this post.
Hello all,
Would love to see a Display Information setting added, so we can understand how the add-on is operating.
Thanks,
Steve
Hello, I’d like to try PfK with alpha 2 of kodi 18 but the link to the post for adding the test repo leads to a page doesn’t exist. Is there and updated link? TIA
@ruuk
Spanish translation: Spanish.zip (4.8 KB)
    <summary lang="es">Plex para Kodi</summary>
    <description lang="es">Add-on Oficial Plex para Kodi</description>
Edit: Reuploaded. Changed some bad translations
Am I crazy, or has the zip been removed? I’m unable to find it anywhere in this post.
Here’s the repository zip, until I can add it to the first post:
repository.plex-1.0.0.zip (30.6 KB)
script.plex-0.1.7a2:
Add Italian translations (thanks to iz8mbw)
Use Kodi time format setting (Issue #90) (thanks to pannal)
Restore last window when starting the add-on while it is running (Issue #126)
Add Portuguese (Brazil) translations (thanks to DiogoAbu)
Add ability to exit search edit box with previous menu (escape) button (Issue #194) (thanks to pannal)
Only play unwatched media when pressing play or shuffle and filtering for unwatched (thanks to tlt21)
Fix issue with duplicated icons whe fast-scrolling a hub (Issue #177) (thanks to pannal)
Fixed GUI not responding after public IP renewal (thanks to pannal and mkliche)
Advanced setting: Automatically seek selected position after a delay (Issue #172) (thanks to pannal)
Advanced setting: Use skip step settings from Kodi (Issue #133) (thanks to pannal)
Advanced setting: Use Plex/Kodi steps for timeline (Issue #133) (thanks to pannal)
OSD-Autohide improvements (thanks to pannal)
Show post play on user stop when item is considered played (thanks to pannal)
Use Unplayed/Played instead of Unwatched/Watched (thanks to pannal)
Fix issue with cast popup displaying partially offscreen (thanks to pannal)
Various fixes for incorrectly transcoded playback (Issue #201) (thanks to pannal)
Get the repo zip here:
Note: Advanced settings are in the Kodi addon settings - i.e. the settings you see when you click settings from the context menu when browsing add-ons.
This trial version is now more than 3 months old.
When will it be effectively released and when can new features be expected?
Assuming this is dead and when v18 Leia releases we all jump to PKC?
This is my go-to Plex client, I really hope it hasn’t been abandoned. I’ve been holding out hope for collection support, but I don’t think it is ever coming :slightly_frowning_face:
Just came on here to check if this is still in active development? This is my go to Plex client and hands down the best, stable and most trouble free media player. Its a real shame if this has now been abandoned.
A question asked often and never answered.
Maybe @elan can confirm one way or another.
As I noticed is the case with the Microsoft store app.
I think you’re asking about the Plex for Kodi app? I don’t have much news, it’s not currently under active development by our engineers, but being open source of course allows for external contributions.
Ah OK.
Much appreciated. It still actually works pretty well. Not my “main” Plex client but one I still use occasionally. :grinning:
Pretty sad news. It is a great great addon missing some features. Worth to improve on it.
:pray: Thanks
