@keithah
I installed it the same way I always have direct from the kodi ppa. It is very odd as it was working fine on mint 18 installed in the very same way basically:
Add ppa
apt-get update
apt-get install kodi
If I get a chance I might try a reinstall of mint 18.1 later and see if it works. Updating those python3 packages (pyopenssl, crytography) shouldnt of caused it since kodi use’s it’s own internal python build I believe right?
On Linux Kodi uses the system python, so thats exactly what happened.
Unfortunately, since this is likely a generic issue with many Kodi add ons, I suggest going into the Linux section of the Kodi forum to get support, I’m not a Linux desktop user, the main dev is, and isn’t experiencing these issues. :\ (he’s on Ubuntu)
Any chance these betas could be put in a repo so people can just add that repo to KODI and auto update to the latest beta? I don’t mind bleeding-edge or the reporting that goes with it, I just wish I did not have to check the site and fire up adb each time I wanted to update.
Currently using revision 100a12. All the versions have the same issue for me in the episode view. I am using cloud storage and going to the episode view causes a download of all the episodes shown underneath. Ideally this should only be a thumbnail download from the meta data folder but for some reason the Plex addon does a full read on the other episodes. So when I enter the episode view and click play on the episode it tries to pull the episode from the cloud storage but all the other episodes are being pulled, one after the other, so it times out. See below…
Btw is there a PlexForKodi.xml profile I need to download for my plex server or what profile does it use? I am runnning LibreElec on an Amlogic s805 and while it supports h.265 main it does not support main 10 but Plex still tries to direct play main 10 and the file either fails to play or plays in slow motion and buffers. I would like to know if there is a place I can edit to force it to transode when h265 10bit and only direct play 8bit. Thanks
@keithah Thanks I’ll get those logs if I can. The issue only occurs on Plex for Kodi because none of the others that I have used, which are the Android client, Plex from the Windows App store, Plex Home Theatre for Windows, Plex for Sony Tv and Plex for Samsung, have the same view when selecting an episode, which in Plex for Kodi is the selected ep with other eps underneath. In the others when you select an ep it just shows the info for that one ep, so only that one is pulled from cloud storage. Also, in the others you see thumbnails for all the episodes in the Season view but even in that view all the files are not pulled from storage, only the thumbnail is shown. That is the way it should be in the Plex for Kodi episode view also I think. Just my 2c
Ähm… yes openelec or rasplex is better :-& #-o
it worked up to #0114, 14-Jan-2017, tested some later builds, not working. and maybe another one has it working with the latest builds
I meant final Kodi 17, you’re talking about alpha 18, don’t bother, it’ll be months before its useable.
Guys just have patience, if I’m not mistaken they work in a private repository and make it public once it’s kinda ready.
Also just take a look at PMP, where it’s (or hopefully was) way worse.
