i just get this by following the readme.txt :
Last login: Wed Feb 5 20:01:17 on ttys000
ives-macmini:PlexConnect iveflammang$ sudo su
sh-3.2# mkdir -p /update/OSX
sh-3.2# /Users/iveflammang/Desktop/PlexConnect/update/OSX
sh: /Users/iveflammang/Desktop/PlexConnect/update/OSX: is a directory
sh-3.2# cd /Users/iveflammang/Desktop/PlexConnect/update/OSX
sh-3.2# chmod +x install.bash
sh-3.2# ./install.bash
usage: git [--version] [--help] [-c name=value]
[--exec-path[=]] [--html-path] [--man-path] [--info-path]
[-p|--paginate|--no-pager] [--no-replace-objects] [--bare]
[--git-dir=] [--work-tree=] [--namespace=]
The most commonly used git commands are:
add Add file contents to the index
bisect Find by binary search the change that introduced a bug
branch List, create, or delete branches
checkout Checkout a branch or paths to the working tree
clone Clone a repository into a new directory
commit Record changes to the repository
diff Show changes between commits, commit and working tree, etc
fetch Download objects and refs from another repository
grep Print lines matching a pattern
init Create an empty Git repository or reinitialize an existing one
log Show commit logs
merge Join two or more development histories together
mv Move or rename a file, a directory, or a symlink
pull Fetch from and merge with another repository or a local branch
push Update remote refs along with associated objects
rebase Forward-port local commits to the updated upstream head
reset Reset current HEAD to the specified state
rm Remove files from the working tree and from the index
show Show various types of objects
status Show the working tree status
tag Create, list, delete or verify a tag object signed with GPG
'git help -a' and 'git help -g' lists available subcommands and some
concept guides. See 'git help ' or 'git help '
to read about a specific subcommand or concept.
IF YOU CANCELED THE INSTALLATION OF GIT RERUN THIS SCRIPT. DO NOT CONTINUE UNTIL GIT IS INSTALLED YOU HAVE BEEN WARNED!
PROCEED ONLY IF YOU INSTALLED GIT PRIOR
sh-3.2#
<------click install if prompted
