Plexify | OS X Application
This project has been declared dead by the author:
https://mobile.twitter.com/iCyberony/statuses/428340382116872192?screen_name=iCyberony
Plexify 1.1 RC
The response to our first public beta has been great (well, mostly). The beta version has been downloaded more than 2500 times. So we decided to not stop development and just do what we were doing all this time - make Plexify better. Todays update contains a lot of bug fixes and new features you'll like. We fixed all known bugs and brought back the restart feature along with the new "force shutdown" feature... Still not excited?!
What's New in 1.1 RC?
  • Auto-start is fixed
  • Uptime feature is fixed
  • Advanced settings is fixed
  • New Welcome & Installation window
  • New Advanced installation method
  • Autoupdate from GitHub
  • Ability to choose your own certificates
  • Fixed Apple TV certificate installation bug (welcome window)
  • Added Help tab
  • Restart functionality is back (Just click stop button while holding ALT/Option key)
  • Fixed bug with PlexConnect.log permission
  • Added "Force Shutdown" functionality (click start/stop button while holding Control key)
  • Faster way to detect local IP
  • Now we're cloning GitHub repository instead of just downloading, even without git being installed on your computer
  • Added ability to choose versions (branches) on installation
  • Embeded PlexConnect Wiki (Partly)
  • Better integration with PlexConnect
  • Improved stability and performance
What's New in 1.1 Beta?
  • New User Interface
  • Keyboard shortcuts (quit, preferences)
  • New Preferences Window
  • Welcome guide to help you configure Apple TV certificate
  • New Icon ( Application and Menubar )
  • Certificate generation
  • Download and Install PlexConnect from Github
  • Password will be asked only once!
  • Changed the way to launch and terminate PlexConnect
  • Shows your local IP address
What's next?
Here's what we're planning for the next release of Plexify (Coming Soon)
  • Scheduled startup and shutdown
  • 10.6 Support
  • More global keyboard shortcuts
  • Localizations
  • Detection of common errors
  • Notifications for 10.8+
  • Simple way to change settings.cfg from Plexify
  • Ability to use your computer as a refrigerator for beer . . .
System Requirements
10.7+ | Tested on: 10.9, 10.8.5, 10.8.4, 10.8.3, 10.8.2, 10.8, 10.7, 10.7.5, 10.7.3,10.7.1
Contacts
Requests: vahagn.mkrtchyan@mit.edu
Developers: vahagn.mkrtchyan@me.com (iMessage, please use only if you're a developer)
How to Give a Feedback?
Check whether the bug was already reported or not. If not, just write a simple post describing the problem you have. Please, describe how to reproduce it and specify your OS version, also attach the log file.
Download 1.1 Release Candidate | 2.7 MB
_____________________________________________________________________
We're accepting donations, check Settings ❯ Donate for more details.
I'm planning to buy an Apple TV, so that I can make Plexify even better.
Well, how is it made then?
Download link?
This app working on my 10.9 well good, yesterday done testing and minor changes
Coming soon localization and automatic update plexconnect )
i testing this app today, maybe do some changes...
Sounds great, nem4ara, could you give link to download ? (test version?)
Idea and test - me
Programming - Vahagn (Cyberon)
Test app, and write comments!
And what is options you want see in app?
Stay tuned
And Hello from Russia
Coming soon:
Localizations
Autoupdate from GitHUB
App for windows
Could you send a non cyrilic link, so it will be easier to download. Thanks for your work in advance.
Add direct link to dropbox
Thanks nem4ara it works very well for me. Is there a way to get rid of the computer asking for the password when we start the service ?
By the way, GREAT JOB.
Working on this problem
Please test and add your comments
Right now, I'm at work and I just try your software from my home remote server. I will tell you more this afternoon when I'll be home with my Apple TV.
Looks great
Do i have to sign to this site to download?
And a few things&questions:
1. Change the bar logo, it should look like the icon of the applescript apps but black only .. I can make one :)
2. How do i tell this app where is my PlexConnect folder and trailers.pem?
3. If you can make this app download the PlexConnect folder to itself and run it from there, and update it automatically on every update from github, and on launch to ask for trailers.pem and save it in the app so it can be deleted from the original place, it'll be so awesome.
4. If you can make it show the guide to change dns on ATV and link to the guide to make IP permanent, this app will actually  be perfect & should become the official method :)
Maybe there is a way for your software to remember the password ? I don't know, i'm a real looser concerning programing. By the way, I'm in France and if you need a french translation for your software I can do that.
Please upload the next version of this awesome app to other upload server.
People don't want to Sign up to unknown website to download stuff .. Espacially when most of us don't know russian :)
Edited:found the dropbox link. Sorry and thanks :)
How should the app find the trailers.pem?
We can always give it access with keychain access but it'll not be perfect ...
Tomer1749, nem4ara just add a DropBox link so you don't have to login on the russian site to download. In fact when you start the software the first time, you can enter your own PlexConnect folder (this can be change in the settings after that), you don't have to tell where is your trailers.pem. I will say more this afternoon.
So the app have trailers.pem inside it?
If so, it's really nice and should be done with the PlexConnect folder .. The app should put it in itself and update it automatically from github-then it'll be so user friendly!
Tomer, how do you give the software a keychain access ??
Looks great
1. Ok. Wait icon
2. In setting you can change your plexconnect folder.
3. Ok
4. Ok
No Tomer, sorry the app doesn't the trailers.pem inside, it just use the existing one, for now it's just a kind of remote that use your existing PlexConnect folder, i doesn't install PlexConnect on your computer. But since I was having problems for an autostart with the Mavericks OS, it is a great solution for me. (Except for the administrator password that prevent my system to autostart completly on his own).
