Hi everyone,
since yesterday i got my Odroid-C2. If i use directplay, videos starting Stucking.
Ich i user Force transcode everything is fine.
So, is it possible to change cache? I mean using a HDD or something? Becaus my SD Card is just 8GB.
Also, is it possible to just change the Videoquality and leave the sounbd original? It is because of HD Master Sound, If i use Transcode or limit the dandwith, HD Master sound isnt available anymore.
Hopefully everyone understood what i mean.
Thx and bye
When you say ‘Stucking’, do mean it’s stuttering? I have an issue with videos having difficulty syncing the audio and video and there is a stuttering effect when starting or skipping a video. It’s thought to be related to the driver versions of the Hard Kernel released Linux Kernel. I’m hoping Hard Kernel will release a better version in the future.
Have you tried setting Preferences > Playback (screen icon) > Advanced Video > Adjust display refresh rate > Always
If you have a TV that supports 24hz playback, that should help. Especially in the next released version. If you have a TV like mine, that only supports 50hz and 60hz, it’s still an issue. Also, adding an audio delay makes it worse.
